Which CarPro Iron-X (Iron Cut) bottle size?
Discussion in 'Car Detailing Product Discussion' started by Chaseme, Mar 27, 2011.
  1. Chaseme
    Chaseme DB Forum Supporter
    Phil has a 500mL, 1L and 5L sizes available in the Iron-X (non soap) product.
    So I know which size to order...
    My question is how much would an average sedan sized vehicle use up?
  2. dankfanatic
    dankfanatic DB Forum Supporter
    i used about 8oz or so on my 3series sedan. seemed like quite a lot, but i guess others have used about the same.
  3. GDAL
    GDAL Super Moderator
    buy the 5L
    You will use about about 375mL per car (about 75% of a 500mL bottle).
  4. d964
    d964 Two Bucket System Washer
    Should be round 100~150ml , no need to spray too much all over,
    you can spray it some and agitate /rub it with soft sponge on surface.. let it work for 5 min , then rinse off.
    good luck
  5. GDAL
    Hello Avi ... could you please post a vid that shows how much you actually spray on a panel? It would be great if you could use a white car for the vid. I've tried many times to use so little, but I can't seem to get enough coverage even when I use a sponge.
  6. 911Fanatic
    I've been using approx 250ml (8oz) per car so far. I spray pretty much all surfaces.
  7. Danny
    Danny Nuba Guru
    Would you think I need IronX even though I have Cquartz already applied? Or can I use a light clay to clean the surface say in half a year or will claying damage the coating? I have been wanting to get IronX but have not acted on it.
  8. d964
    Hi Gianni , well , i dont have such, i think Misha test on white car once
    you dont need to spray so much, you can spray and rub all over with soft sponge, i dont know if i can post video here, Phil need to confirm... there is good video showing how much you use for wheel cleaning.. so you can have some idea..
    just do small search on ironX on youtube and you will see.
  9. Danny
    Danny Nuba Guru
    Avi any thoughts on my post?
  10. d964
    Sorry Danny, miss that,
    use the soap gel, will be great enough for you after cquartz and clay,... soft clay wont harm the cquartz,
    you will see , if you will wash monthly with the IXSG you wont need much to clay even..
  11. Danny
    Danny Nuba Guru
    Thanks Avi I will pick up some ixsg. I have one more question I am worried if I get marring from my car cover will 85rd and a blue pad be ok to correct the marring or will it remove cquartz?
    Sent from my HTC EVO using Tapatalk
  12. d964
    Most likely you wont get marrings from the car cover with Cquartz, .but if yes, 85RD with soft pad wont remover the CQ
  13. Danny
    Danny Nuba Guru
    Thank you I did get marring on it from the cover but before cquartz was applied. If I do get marring would it be wise to polish them out and then put two coats of cquartz on the marred sections
