So as the thread states where do you lovely people acquire from wool pads? I want to give a few a try. I've tried the LC purp but I want to try others. Thanks in advance.
I just responded in your Z post about wool pads...glad to hear you want to try them. I would suggest 2 for your arsenal...pfw and a black Megs wool. With the strength of Megs 105 or Menz PG, you really won't need an old fashioned thick white wool pad...besides, the mess they make is not worth it, IMO.
I currently have the PFW and Edge wool pads that I can't remember exactly where I purchased them. I'll be moving to the Micro-Surface Tuf Buf almost exclusively but I still want to try out the 3M ones that Dana uses and the Meg's wool pads.
i get mine from autoshine car care .com in the uk. the guys name is tony spears, great chap and a very good detailer. ex swissvax instructor of 15 years, knows his stuff and the pads arent that expensive. the meguirs solo wool pads i have to say are slowly drawing me in as there perfectly centred and the + with the solo's is there is different grades of wool! check out mr rubbish boys also as he has wool heads which look quiet good:thumb:
Right now I have PFW and the Megs so1o Wool pads. But like Denzil, I plan on going to all TufBuf, and just keep my Megs burgundy for the heavy hitting.
Thanks for all the info guys. So the only wool i've tried is the PFW by LC and I did find it good although I find that it cakes up really quickly. I guess I could spur. So how would you guys rank the aggresiveness of the different pads for wool. BTW what do you guys recommend to replace Menz PG? I find it too thick. I want something smoother. Again thanks for the help.
spurring does help just dont get to angry with it or you will kill the wool. as for wanting a smoother polish i use the menz power gloss ( not a lot ) and mix with intensive as this is less aggressive and more lubricated.:thumb:
Is there an alternate from like Megs? Or a diff brand? I've used PG with OPT Polish as OPT seems to go on forever. Thanks for the info Scott
As you know, you can step up a pad (ie to wool) and then use a less aggressive compound. If the finish needs correction, but not brutal, I like to use a pfw pad with UCCL...that's by Presta and not many guys on here use it, but it's great, IMO. Just make sure you spur often and if the paint is dirty, you will find you will need to clean the pad with APC every few panels. It is worth the effort to do so. Just spin it dry and Bob's your uncle. SIP is also a good alternative.
thanks for the info richy. Mucho Gracias. So if you used say PFW with Menz PF how does it finish off? Would the cutting power be greater than say SIP with Yellow compounding pad? Hazy or can you jump straight to a final polish?
It finishes off better than you'd think, although once again, good technique is going to make a massive difference. I don't like using yellow compounding pads as they generate a lot of heat...the advantage of pfw is low heat by comparison. Would the cutting power be greater with pfw than the yellow: yes it would. I generally follow my compounding with 85rd or 106 with a black or blue pad for a fantastic finish. Here's a few examples that I will show you just for illustrative purposes: Caddy G37 using fw and X3 Sebring with either X3 or 105 Hope that helps illustrate the different approaches you can take.
