Jesse- Can you speak to the interaction between these products? To be more specific, let's say my end goal is a super clean wheel prepped for Rim Shield. If I use Wheel Cleaner, is the iron decontamination product going to be required as well? Also, I am assuming the nano protection in WC and RS are compatible, but let me know if not. Thanks!
Hi! Are you referring to the nano wheel cleaner "Clean & Coat"? C&C is more of a maintenance wheel cleaner and may not remove some deeper, burned in brake dust. Deironizer on the other hand will! If you're prepping the wheels for RS, I would start with Deironizer. This will remove the baked-in brake dust and give it a very good deep cleaning. Then C&C can be used to clear up anything that DI may have left behind and it will also leave a very good nano base in preparation for RS! Let me know if you have any more questions! - Jesse
