What will do the trick on these?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by dsms, Mar 21, 2008.
  1. dsms
    dsms DB Forum Supporter
    All 4 wheels of this BMW 330 have this same baked on brake dust/road tar in between the spokes. I cant get it off and so far I have tried everything I have with an assortment of wheel brushes.
    -Clay
    -Megs safe-d (3:1)
    -p21s gel
    - AG intensive tar remover
    Nothings is working, I was thinking mothers power ball because its a tough area to get into, any suggestions.
  2. bigpoppa
    bigpoppa Jedi Nuba
    Try a paint cleaner or polish.
    If that doesn't work, maybe Meguiar's Wheel Brightener.
  3. reefer_bob
    reefer_bob Obsessive Detailer
    It almost looks like it's pitted into the finish. Can you feel it with a fingernail as being raised?
  4. m4gician
    m4gician Birth of a Detailer
    maybe wetsand it with 2000 grit then hand refinish with compound?
  5. dsms
    Tried a little SIP and even M105, didnt do a thing!
  6. OrngeZ
    OrngeZ Birth of a Detailer
    use a more aggressive clay with a lot more swearing...works for me all the time :)
  7. dsms
    Dont have amore aggressive clay and have been swearing constantly. The stuff just wont come off.
  8. devast8
    devast8 New Member
    is it tar? tarminator maybe?
  9. Gemini13
    Gemini13 Obsessive Detailer
    That was my thought also.
  10. dsms
    Could be, but after several attemps with AG intensive tar remover nothing came off.
  11. Joyriide1113
    Joyriide1113 Any Rag Vehicle Washer
    That is baked on brake dust. Try an acid based wheel cleaner. Brake dust is basically metal particles and Acid breaks down metals. Thats why these types of wheel cleaners work soo well. You're wheels are painted so it should be safe, just thoroughly rinse and even give it a quick one with some regular soap afterwards.
    Meguiars Wheel Brightner, Poorboys Spray and Rinse, I know chemical guys makes one, and even Meguiars Hot Rims is Acid based (although light).
    If not, try some aggressive clay.
  12. FMINUS
    FMINUS DB Pro Supporter
    :headbang:
  13. dengood1
    dengood1 Birth of a Detailer
    Powerball with some AIO should work. If not, try one of the acid based cleaners.
  14. dsms
    I think im going get some megs wheel brightner. What dilution to remove those particles?
  15. Tonya
    Tonya Welcome to Detailing
    I called Meg's the other day. They said as long as the rims are not scratched, pitted or anything where the acid would get under the clear you should be fine. I talked to a few member about the brightner. They all say make sure you rinse very well!!
    Good luck!:headbang:
  16. TexasTB
    TexasTB Obsessive Detailer
    Megs Wheel Brightener is some of the best wheel cleaner I have used hands down.......
  17. dsms
    I just ordered Megs WB and their agressive clay, hoping it will help on the really bad wheel jobs. Im not sure of which dulition to use for the WB. I guess I will fill one bottle 10:1 and another maybe 4 or 5:1 for the really dirty wheels, is this safe? Any delicate or coated finish wheels will get p21s instead.
  18. Nica
    Sounds like a job for Meg's Wheel Brightener but be very carfull with this stuff, it's really strong. I've only used it once and may it's strong...to be honest I don't like using it but if you have no choice well you have no choice. I used Wheel Brightener diluted 4:1.
    Keep us posted oh how you make out.
  19. dsms
    The use of an acid based wheel cleaner makes me nervous but I know there is times when I will need it, like on those bmw wheels. I have already gone through a lot of p21s gel and that stuff is expensive! Hows stoners tarminator for tar spots?
  20. porta
    porta Jedi Nuba
    Acid wheel cleaner.
