What type of sponge do you use?
Discussion in 'Car Detailing Product Discussion' started by newbie001, Oct 21, 2010.
  1. newbie001
    newbie001 Birth of a Detailer
    It seems that a lot of people are using grout sponges from HD or Lowe's, and just wondering anyone's thoughts on car wash sponges from Walmart. It claims to be clear-coat safe, etc...
  2. dave_zok
    dave_zok Guest
    I like Adams and chemical Guys wash pads. Main thing is that you clean them after your wash your car so there is not jumk in them when it comes time to use them again.
  3. JoeyZ
    JoeyZ Obsessive Detailer
    It varies....but I use the SV Wash Mit, and nice plush mit that DD sells.
    To be honest, the one phil sells is my favorite.
  4. Pats300zx
    Lowes Grout sponge for me...
  5. Emile
    Emile Welcome to Detailing
    Uber Wash Sponge is my favorite for car washes, Shmitt Wash Mitt is a close second.
    For ONR washes, I love my microfiber "noodle" wash mitts.
  6. P1et
    I used to use the Shmitt, but they seperated so quickly. The shape is also a bit awkward, and it's easy to miss spots.
    I used the Zymol sponges for a bit, but found them to flatten too quickly. So I tried Phil's Uber sponge and found it to be a bit smaller than the Zymol sponge, and it holds more water and does go flat like the Zymol sponge.
    So the Uber sponge it is for me. Cheap too.
  7. kakeuter
    kakeuter DB Forum Supporter
    I have the grout sponges, MF mitts, chenelle mitts, MF foam and the Shmitt.
    I like the MF mitt for ONR, Chenelle, Shmitt and grout sponge hold soap fairly nicely.
    Looking forward to ordering the Uber Sponge.
  8. Minicoop831
    Minicoop831 Birth of a Detailer
    I use the uber
    Sometimes the uber gets a bad rep, its meant for cleaning a well maintained vehicle. It not aggresive and pampers your finish
  9. co78
    co78 DB Forum Supporter
    uber sponge with car soap, microfiber noodle mitt for ONR washes.
  10. Hum-Benz
    Hum-Benz Wax on..Wax off
    For the past yr. I've been using the Home Depot grout sponges.
  11. agpatel
    agpatel OD On Detailing
    uber sponge...only one i have used in a long time but now i like to use my RG sheepskin mit and it is amazing!
  12. Danny
    Danny Nuba Guru
    I like my DI sheep skin mitt after I wash with it I fill up my sink half ways with clean hot water and let it float in there, any particles that were still in it after rinsing fall right out.
  13. rwisejr
    rwisejr DB Forum Supporter
    I have tried so many different wash media and Once I tried the Uber sponge it simply just flat out works the best for me. Cheap and simple.
  14. domino
    domino Welcome to Detailing
    this is something ive been experimenting with ever since i got my first car 10 years ago
    ive used wool/sheepskin mits, mf mits, foam sponges, sea sponges, schmidts .....everything
    and ive gone back to using regular rectangle foam sponges. Mitts i found trap dirt and never clean out fully - back into a solid black car in May and after first wash what i thought was an impeccably clean and maintained MF mitt put fine scratches in the paint (lucky i hadnt corrected it yet). So i switched back to a foam sponge
    the advantage is i buy them locally cheap, like under $2, so i just throw them out every couple months. I soak them in hot water before use to soften them up
    ive also been experimenting with wheel sponges, and atm am using a 3 finger wool mitt from rubbishboys. I like it for ease of use but its wool dramas all over again with the pungent smell despite cleaning it out well after use. So looks like ill be back to using an MF mitt on wheels
    id like to give the uber sponge a go, i should have added a few to my last order.....bummer
  15. supercharged
    Uber sponge is very similar to Zymol Sponge...
  16. BigAl3
    BigAl3 Birth of a Detailer
    agreed and not to mention, the (grout) sponge (both lowes and HD work pretty well) rinse out easy and are very pliable too (the lowes more so). can't beat it for $2, and not to mention you can delegate them to wheels once they start falling apart...
  17. newbie001
    Thanks everybody! Just to confirm, are these the ones that everyone has been mentioning:
    Home Depot Sponge
    Lowes Sponge
    Uber Yellow
    And also to confirm, are most people recommending the sponge for traditional washes, and not ONR washes? For ONR I'm better to stick with a MF mitt, noodle mitt or wash pad?
    Thanks again!
  18. BigAl3
    the one you want from lowes is this one...
    ProLine Tile & Grout Sponge
    the one from HD is this one... [​IMG]
  19. newbie001
    Thanks. That's actually the one I was originally looking at, not sure why I grabbed the link for the 'easy grip' version...
    Thanks again!
  20. JPerrydore
    JPerrydore Birth of a Detailer
    I've been using the Schmitt lately and I like it, however the odd shape does make it hard to ensure you get every spot. For example on my Avalanche the rear tailgate has a portion where the handle is that is difficult to reach into with the schmitt. So I end up having to go back over it or ensure I get it the 1st time around.
    I am considering changing it up.
