what products do you guys recommend for this??
Discussion in 'Car Detailing Product Discussion' started by Lito, Jan 21, 2011.
  1. Lito
    Lito Any Rag Vehicle Washer
    Hi!
    Well, I have some BAD caked on tree sap on the roof of my A4 and on the windshield... I've tried some CG Grime Reaper, with "some" luck... the sap starts to "bleed" but never gets fully soft to be removed...
    I was thinking something along the lines of Tardis (not available on the US :( )...
    Please, understand that I'm outside the US, and I can get pretty much any product from the US... i can't buy aerosol products :( so no tarminator for me..
    Let me know what should I try!
  2. CU2MIKE
    CU2MIKE Guest
    Try white vinegar
    Put vinegar on a MF towel, cover the towel directly over the tree sap, I'd say check every 5 seconds or so and see if it improves.
    I know white vinegar is good for removing water spots, maybe it'll work for tree sap too?
  3. Danny
    Danny Nuba Guru
    3M general adhesive remover spray on the area let it sit for a little a minute or two this should break down the sap then wipe it using light pressure it my need several applications but it will work. Use out of direct sunlight. I also suggest washing the vehicle first to get the sap wet and to help it break down. Then use 3M general adhesive remover. You could also try using the plastic razor blades the Phil carries with the 3M
  4. Rcrew
    Rcrew Wax on..Wax off
    Yup, 3m adhesive remover shouldn't be too hard to acquire. An aggressive clay bar might help as well. More than likely you will need to utilize some machine polishing for the remnants of it.
  5. rfinkle2
    rfinkle2 DB Forum Supporter
    ^+1
    and... i've found autoglym srp to be really good (if let dwell) on road tar and tree sap
  6. billyblooshoes
    best and easiest way to remove tree sap is isopropyl alcohol (91%). can get it at any drug store for just around a dollar a bottle. just get a microfiber, and soak an area of the towel with it. then, hold the saturated part of the towel on the tree sap for about 30 seconds. this will start to break it down, then you should be able to gently wipe it away. works every time.
  7. Reflect
    Stoner's Tarminator has always been a favorite of mine for this sort of thing.
  8. Misha
    Misha Nuba Guru
    + for tarminator. get MF and spray tarminator on tar, let it sit for a min and wipe off, repeat untill tar or sap is gone, i sprayed some on mf towel and rubed it on sap carefully untill i got most of it. then let it sit till sap was easy to wipe off without rubbing paint. removed year old sap
  9. kyoshiro
    kyoshiro DB Forum Supporter
    sadly lito cant buy tarminator as its aerosol products :(
  10. Misha
    Misha Nuba Guru
    i had good luck with turtlewax tar remover. some sap requires different chemical to remove it. tarminator doesnt work 100% of the time
  11. Deep Gloss Auto Salon
    Agreed
    Sent using Tapatalk
  12. pektel
    pektel DB Forum Supporter
    I'm wondering if kleen strip prep all would work here...
  13. billyblooshoes
    isopropyl alcohol always works, and most of us should have it anyway. just use that.
  14. Tire Shredder
    Tire Shredder Jedi Nuba
    tarminator! best stuff I have ever used
  15. rfinkle2
    i think he mentioned he can't import aerosol
  16. Lito
    WOW the IPA did it!!! it's just going to be a PITA to do the whole roof :)
    Thank you all for the quick responses!!!
  17. sarah_whitlow
    sarah_whitlow Virgin Detailer
    Try superior quality car detailing products built with latest green cleaning technology. It will definitely give you perfect cleaning result.
  18. junebug
    junebug Jedi Nuba
    If you have a Lowes or Home Depot type of store - get some Goo Gone. I cleaned an elderly Pontiac that had sat under the same tree for 3 friggin years. You couldn't even tell the true color anymore. Goo Gone cleaned up nicely! But, you're going to have to wash with a strong soap afterwards and apply a good sealer or wax.
