what info is stored in exif file
Discussion in 'Detailing Bliss Lounge' started by Misha, Jun 10, 2010.
  1. Misha
    Misha Nuba Guru
    needed to check shutter count on my dslf so found exif tool(cant find one for mac thats easy to use)
    here is what info it gave me, i kinda was surprised how much there is. not all pic have same info
    ExifTool Version Number : 7.86
    File Name : IMGP5251.JPG
    Directory : E:/
    File Size : 3.9 MB
    File Modification Date/Time : 2010:06:09 19:27:04-04:00
    File Type : JPEG
    MIME Type : image/jpeg
    Exif Byte Order : Big-endian (Motorola, MM)
    Make : PENTAX Corporation
    Camera Model Name : PENTAX K20D
    Orientation : Horizontal (normal)
    X Resolution : 72
    Y Resolution : 72
    Resolution Unit : inches
    Software : K20D Ver 1.00
    Modify Date : 2010:06:09 19:27:01
    Y Cb Cr Positioning : Co-sited
    Exposure Time : 0.3
    F Number : 3.5
    Exposure Program : Program AE
    Exif Version : 0221
    Date/Time Original : 2010:06:09 19:27:01
    Create Date : 2010:06:09 19:27:01
    Components Configuration : Y, Cb, Cr, -
    Flash : Off, Did not fire
    Focal Length : 28.0 mm
    Pentax Version : 4.1.2.0
    Pentax Model Type : 0
    Preview Image Size : 640x480
    Preview Image Length : 29524
    Preview Image Start : 5544
    Pentax Model ID : K20D
    Date : 2010:06:09
    Time : 19:27:01
    Quality : Premium
    Flash Mode : Off, Did not fire; Internal
    Focus Mode : AF-S
    AF Point Selected : Fixed Center
    ISO : 400
    Exposure Compensation : +1.7
    Metering Mode : Multi-segment
    Auto Bracketing : 0 EV, No Extended Bracket
    White Balance : Auto
    White Balance Mode : Auto (WhiteFluorescent)
    World Time Location : Hometown
    Hometown City : New York
    Destination City : New York
    Hometown DST : No
    Destination DST : No
    DSP Firmware Version : 1.00.00.01
    CPU Firmware Version : 1.00.00.01
    Effective LV : 5.0
    Image Processing : Unprocessed
    Picture Mode : Program (HyP); 1/3 EV steps
    Drive Mode : Single-frame; No Timer; Shutter Button; Single
    Exposure
    Preview Image Borders : 28 28 0 0
    Lens Type : smc PENTAX-FA 28-80mm F3.5-5.6
    Sensitivity Adjust : 0
    Image Processing Count : 0
    Camera Temperature : 24 C
    AE Lock : Off
    Noise Reduction : Off
    Flash Exposure Comp : 0
    Image Tone : Landscape
    SR Result : Stabilized, Not ready
    Shake Reduction : On (7)
    SR Half Press Time : 1.13 s
    SR Focal Length : 28 mm
    Shutter Count : 24517
    Dynamic Range Expansion : Off
    High ISO Noise Reduction : Strong
    AF Adjustment : 0
    Black Point : 0 0 0 0
    White Point : 11968 8192 8192 13568
    Picture Mode 2 : Program AE
    Program Line : Normal
    EV Steps : 1/3 EV steps
    E-Dial In Program : Tv or Av
    Aperture Ring Use : Permitted
    Flash Options : Auto
    Metering Mode 2 : Multi-segment
    AF Point Mode : Fixed Center
    Focus Mode 2 : AF-S
    AF Point Selected 2 : Center
    ISO Floor : 100
    Drive Mode 2 : Single-frame
    Exposure Bracket Step Size : 1.3
    Bracket Shot Number : n/a
    White Balance Set : Auto
    Multiple Exposure Set : Off
    AE Exposure Time : 0.3
    AE Aperture : 3.5
    AE ISO : 400
    AE Xv : -1.625
    AEB Xv : 0
    AE Min Exposure Time : 1/3862
    AE Program Mode : M, P or TAv
    AE Max Aperture : 3.4
    AE Max Aperture 2 : 3.5
    AE Min Aperture : 23
    AE Metering Mode : Multi-segment
    Flash Exposure Comp Set : 0
    Auto Aperture : On
    Min Aperture : 32
    Lens F Stops : 6
    Nominal Max Aperture : 3.4
    Nominal Min Aperture : 23
    Max Aperture : 3.4
    Flash Status : Off
    Internal Flash Mode : Off, Normal
    External Flash Mode : Off
    Internal Flash Strength : 0
    TTL DA A Up : 0
    TTL DA A Down : 0
    TTL DA B Up : 0
    TTL DA B Down : 0
    External Flash Guide Number : n/a
    External Flash Exposure Comp : n/a
    External Flash Bounce : n/a
    AE Metering Segments : 4.1 4.1 4.4 7.0 2.9 2.3 3.0 3.3 4.0 3.4 3.0 3.
    1 5.1 3.1 5.0 4.3
    Flash Metering Segments : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    Slave Flash Metering Segments : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    WB RGGB Levels Daylight : 12961 8192 8192 10544
    WB RGGB Levels Shade : 14780 8192 8192 8022
    WB RGGB Levels Cloudy : 13740 8192 8192 9321
    WB RGGB Levels Tungsten : 8316 8192 8192 19560
    WB RGGB Levels Fluorescent D : 17151 8192 8192 9932
    WB RGGB Levels Fluorescent N : 14553 8192 8192 11308
    WB RGGB Levels Fluorescent W : 13578 8192 8192 14058
    WB RGGB Levels Flash : 13740 8192 8192 9932
    Manufacture Date : 2008:01:31
    Production Code : 2.4
    Internal Serial Number : 32540
    Power Source : Body Battery
    Battery States : 4 1
    Battery AD Body No Load : 189
    Battery AD Body Load : 180
    Battery AD Grip No Load : 1
    Battery AD Grip Load : 1
    AF Predictor : -3
    AF Defocus : 2
    AF Integration Time : 142 ms
    AF Points In Focus : Center (vertical)
    WB Shift AB : 0
    WB Shift MG : 0
    Flashpix Version : 0100
    Color Space : sRGB
    Exif Image Width : 3008
    Exif Image Height : 2000
    Interoperability Index : R98 - DCF basic file (sRGB)
    Interoperability Version : 0100
    Sensing Method : One-chip color area
    File Source : Digital Camera
    Scene Type : Directly photographed
    Custom Rendered : Normal
    Exposure Mode : Manual
    Focal Length In 35mm Format : 42 mm
    Scene Capture Type : Standard
    Contrast : High
    Saturation : Normal
    Sharpness : Hard
    Subject Distance Range : Distant
    Compression : JPEG (old-style)
    Thumbnail Offset : 54420
    Thumbnail Length : 7681
    Image Width : 3008
    Image Height : 2000
    Encoding Process : Baseline DCT, Huffman coding
    Bits Per Sample : 8
    Color Components : 3
    Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
    Aperture : 3.5
    Image Size : 3008x2000
    Lens ID : smc PENTAX-FA 28-80mm F3.5-5.6
    Preview Image : (Binary data 29524 bytes, use -b option to ext
    ract)
    Scale Factor To 35 mm Equivalent: 1.5
    Shutter Speed : 0.3
    Thumbnail Image : (Binary data 7681 bytes, use -b option to extr
    act)
    Circle Of Confusion : 0.020 mm
    Field Of View : 46.4 deg
    Focal Length : 28.0 mm (35 mm equivalent: 42.0 mm)
    Hyperfocal Distance : 11.18 m
    Light Value : 3.4
    i wonder if my GPS camera will have coordinates of location listed here, have to check
  2. smalltrees
    smalltrees Virgin Detailer
  3. vtec92civic
    vtec92civic Nuba Guru
    d ill get you a count.
  4. pektel
    pektel DB Forum Supporter
    i see a shutter count of 24517
