What do you use to measure ounces when diluting?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Kaban, Jan 16, 2011.
  1. Kaban
    Kaban Welcome to Detailing
    Hi fellas,
    I noticed many products require the process of diluting the product itself with water.
    For example, to make clay lube you can mix one ounce of ONR with water in a 32oz. bottle. How do you know how much an ounce is? Do you guys use a measuring tool of some sort like a syringe or do you guesstimate?
    I'd really like to know so that I can start using appropriate tools to make exact measures!
    Thanks a bunch!
  2. rwright
    rwright Birth of a Detailer
    Is this a joke? :shead:
  3. snowking724
    snowking724 Any Rag Vehicle Washer
    Some bottles have marking on them or you can use any measuring cup from your kitchen.
  4. Perfections
    Autogeek.net under "what's new" 1 and 3 oz measuring tools, used by every single detailer out there, it's alittle known secret so you must be new to detailing :)
  5. Dubbin1
    Dubbin1 Jedi Nuba
    It's called a measuring cup...
  6. P1et
    This thread is awesome!!!
  7. jjl
    jjl Birth of a Detailer
    Cough syrup measuring cup for the dilutions that call for capfuls (.5 - 2 ozs) and I have a small measuring cup that for those larger dilutions. You could get creative and get something clear and most people have measuring spoons at home and draw lines for the different volumes you need. Lots of options here!
  8. Kilo6_one
    :thumb::popcorn::support:
  9. luke093
    luke093 Welcome to Detailing
    Shot glass for my soaps :p Otherwise, measurements on the spraybottles
  10. GDAL
    GDAL Guest
    walmart sells a really small measuring cup that measures up to 5 oz. Or you can always buy the HD spray bottles with the pre-measured dilution ratios.
  11. 911Fanatic
    I use little measuring cups like the ones for cough syrup. They are measured up to 30ml which is one ounce.
  12. Deep Gloss Auto Salon
    Same here.....
    Sent using Tapatalk
  13. Emile
    Emile Welcome to Detailing
    If it's a big dilution, like 3:1 I'll just fill up my an empty spray bottle to 24oz and the remaining 8oz of product. Obviously you need to pickup spray bottles that have ounce or mL markings on them.
    If it's a small dilution, like 2oz I use a set of plastic measuring cups. If I have to be very very precise, I have several syringes, some of them measure up to 12mL at a time and some of them up to 60mL (2oz) at a time. Approximately 30mL per ounce.
    A couple of plastic yellow funnels from AutoZone (about $1 each) are a big help when filling up spray bottles.
  14. agpatel
    agpatel OD On Detailing
  15. agpatel
    Actually.....1oz ~= 29.5735 mL...come on Ken!
  16. Perfections
    But it was fun to call it a measuring tool lol :)
  17. Kaban
    Lol thanks for the help fellas! And yes this was a serious question....
  18. domino
    domino Welcome to Detailing
    i use the cup of my palms placed under each other
    also works for receiving holy communion at church
  19. kyoshiro
    kyoshiro DB Forum Supporter
    I eye the volume of the solution and the volume of the water as it goes into the container
    simply by measuring the flow * the amount of time lapsed, you can also tell how much vol is going in
    or you can choose to measure how many cm of liquid is going down * the width and length of the stream and come to an answer
    or when i simply too tired to do mathematics, i'll just use the markings in my kwazars
  20. billyblooshoes
    thats actually a really good idea ankeet. i had forgotten about them since high school chemistry i think.
