what can't you use wheel brightener on?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by npb, Mar 12, 2008.
  1. npb
    npb Virgin Detailer
    anything i should watch out for? any tips on suggested ratios? thanks
  2. sneek
    sneek Nuba Guru
    I wouldn;t use it for anything not from the factory. If you don't know, call the wheel maker and see what they have to say.
  3. togwt
    Even a pH 5.0 acid with a dilution rate of 4:1 (as recommended by Meguiar's for their Wheel Brightener (Ammonium hydrogen fluoride [NH4] [HF2]) results in a pH 4.5 solution. The dilution of an acid doesn’t make it safer as the addition of a molecule of water to a chemical compound, without forming any other products is known as hydration (i.e. dilution causes the pH to decrease) But since pH is not a very good indicator of the strength of the acid in every system, this approach won't always produce the desired results.
    Wheel Cleaners- http://www.detailingbliss.com/forum/f35/wheel-cleaners-1201.html
    Acid wheel surface damage - Boxster Wheels looking grim - Detailing World
  4. SpoiledMan
    SpoiledMan Birth of a Detailer
    Anything uncoated, anodized or that you're unsure of. You need to *KNOW* what the finish of the wheel is before you use anything more than soap and water.
