Since I don't have a heated garage to work in detailing season is drawing to an end here in Northern New England. Are there any recommendations as to the preferred storage conditions for the Wolf's nano sealants? I'm assuming keep them above freezing, correct? Do light exposure and or humidity matter? Temperature swings? Is there a maximum temp for summer and warmer latitudes? Just to be clear I'm not asking what storage conditions the sealants can tolerate but rather what conditions are likely to maximize their usable lifespan.
All car acre products are negatively impacted by wide temperature fluctuations and extremes of high or low temperatures. As far as wax storage is concerned standard room temperature will suffice; a refrigerator provides a stable temperature / humidity, which equates to a longer shelf life to the products. Water-based car care products should not be stored at temperatures below > 35.OF (wax 45.OF) if they freeze they may become unstable and therefore unusable, ideal storage temperature range- 50- 7.OF with an average humidity range. Most car care products have a ‘useful life’ of approximately 2-3 years provided they are stored as above. Keep containers tightly closed and ensure they are not compromised (fractured or leaking seals) store in a dry, cool and well-ventilated place. Keep away from direct sunlight. Do not allow to freeze. Do not store at temperature extremes (below 40 – over 80.OF +) as heat will destabilise emulsified products (wax, polymer sealants, polishes, etc) and avoid extreme temperature swings as the chemicals will become unstable, which will create problems with the performance of the product. Some separate out; others lose their effectiveness if they are heated past a certain point. Most car care products (including Polymers) will separate and may become unusable after being subjected to freezing temperatures The chemical composition of waxes rarely ever change regardless of what form it is in, whether it is melted to a semi-liquid or remains as a semi-solid. Temperature has little to no effect as far as inhibiting the shelf life of wax, a cool temperatures and constant humidity will slow the evaporation of solvents from the wax, thus keeping the wax softer and easier to use over a longer period of time. Shelf-Life Providing their contains have a tight seal, are not compromised by fractures or (air) leaks, and use at least a single stage fluorination of the plastic, so that it is resistant to petrochemical solvents; without this the sides will ‘collapse’, which is actually the solvents in the product escaping through the micro pores of the plastic. All liquid products should be shaken well (not stirred 007) before use a) Polymers have a shelf life of approx 3-5 years if kept in their original containers and stored at temperatures as above b) Polish - technically 2 years, providing the bottle is kept closed, and the product has not separated or the solvents haven’t evaporated by leaching ( the bottle will become semi- collapsed) there should be no problem with use for three years after sale date c) Waxes - will last almost indefinitely, provided that they are stored a sealed in their original containers and in the refrigerator or controlled environment once opened. The liquids should last 18 months if stored at normal room temperature. d) Detailing Chemicals (Wheel cleaners, All purpose cleaners (APC) and etc) have an almost indefinite shelf life if kept in their original containers and stored at temperatures as above, see also Product separation e) Product separation If product emulsion separates it could be indicative of age (but not necessarily past its useful life) shake vigorously for 5-10 minutes and see if the product re- mixes. Product shelf -life may vary from one manufacturer to another, if in doubt check with product mfg or vendor.
Very good information............. Usually I just keep the stuff in my garage with exception to the summer. Winter never gets below 40 degrees in my garage.
Thanks for the input, Jon ! They should be stored about 10 degrees C and if it goes below that, you may see some cloudiness in the sealants, but just get them back into a warm place and they'll be OK! Also, the shelf life of the nano sealants is 2+ years! - Jesse
