Where do you guys get your paper from? I am here at my home depot and all I cab find is 320,400&600 grit sandwet paper. Isn't that a bit rough? Any help would be great. I have a hood to practice on and want to get this technique down. TIA
Go to any automotive supply shop, they usually sell 1000-2000. Detail supply shops will have grits up to 3000. I think walmart carries 3m paper. Look for meguiars unigrit/nikken paper.
I thought that was a little rough. I'll try to find some tomorrow, I'd like to save myself shipping costs and the time it takes to ship
Yikes 320,400&600 those are some aggressive sanding paper...I personally wouldn't use these types of sand papers...I would go to an automotive shop and stick to 1000, 2000, 3000 and if possible 4000 grit papers. Just my :2cents:
What you saw at HD was meant for Woodworking.:giggle: :shead:I personally use 2000 98% of the time, occasionally using 1000.If you have a Rotary I would reccomend this route, as said above a Auto Paint Supply Store will be Source, while there be sure to pick-up a good Sanding Block....Good Luck opcorn: P.S. Just make a few passes at a time. You can always remove more(Paint) But adding to gets costly
You will need 6-inch x 4-inch sheets of Nikkens™ 2000, 2500 and 3000 - grit finishing paper (1000 and 1500 grit is also available, but they are usually used on single stage paint systems, you can start with any grade of finishing paper according to the condition of your paint film surface, but as always use the least abrasive first) next cut or tear three or four pieces of the finishing papers in half and place them in the bucket also. Wrap a piece of the softened Nikkens™ 2000 - grit finishing paper (or whatever grade your paint surface requires) around a Unigrit Sanding Block (see also alternative products) if you're going to be working broad, flat surfaces. Otherwise, you can just fold the sandpaper in thirds. Keep wetting the surface of the vehicle in the area where you're sanding and keep it wet while you work. Place your hand flat on the sanding block / finishing paper at all times and start sanding in short, crisscross strokes. Good luck See also "Wet-Sanding (Colour Sanding)" detailing school section
