We are now a Kranzle Pressure Washer Reseller! In search for a more user friendly pressure washer we have found the Kranzle line. I guess one of the biggest issues everyone had with the Cam Spray was that it ran on 20 amps, not available in most homes and to the avg user. As well some conveniences were not there mainly a hose reel, wheels to move the pressure washer... you get it. Here are a couple units we will be carrying. Kranzle Prosumer 1600 PSI (Electric-Cold) Pressure Washer w/Kranzle Pump K1600 List Price: $975 --- Our Price $670 - Free Shipping within USA Light Commercial Duty, Hand Carried Unit With Steel Frame • Great for estates, HVAC maintenance, screen printing, etc. 110 Volt, 15 Amp TEFC Electric Motor With 25' Cord • GFIC not included; please use on a GFIC protected circuit • Use indoors and outside; can pull water from a tank or lake High Quality Kränzle AZ Industrial Grade Pump • Adjustable unloader lets you set the pressure to suit the task • Multi-hour bypass and run-dry capability prolongs pump life Professional Grade Gun And Lance With Safety Screw Couplers • Knife-jet nozzle cuts through dirt and grime • Includes 33', 1/4" wire reinforced hose w/22mm thread connectors Kranzle Prosumer 1400 PSI (Electric-Cold Water) Pressure Washer K1120T List Price: $1300--- Our Price $890 - Free Shipping within USA Home Or Light Commercial Duty Unit • Great for estates, HVAC maintenance, screen printing, etc. 110 Volt, 15 Amp TEFC Electric Motor With 25' Cord • Use indoors and outdoors; can pull water from a tank or lake • GFCI not included; please use on a GFCI protected circuit High Quality Kränzle AZ Industrial Grade Pump • Adjustable unloader lets you set the pressure to suit the task • Multi-hour bypass and run-dry capability prolongs pump life Professional Grade Gun And Lance With 22mm Screw Connectors • Variojet 0° - 35° (high-pressure wash/soap) for most tasks • Dirt Killer turbo nozzle doubles cleaning efficiency • Exit side chemical injection allows wider selection of cleaners • Includes 50' wire braid reinforced 1/4" hose on handy hose reel Kranzle Professional 1600 PSI (Electric - Cold Water) Pressure Washer K2017T List Price: $1900 -- Our Price $1320 - Free Shipping within USA Light Commercial Duty Unit • Great for estates, HVAC maintenance, screen printing, etc. 110 Volt, 15 Amp TEFC Electric Motor • Includes 35 foot power cord with GFI • Use indoors and outdoors; can pull water from a tank or lake High Quality Kränzle APG Industrial Grade Pump • 10 year manifold warranty • Adjustable unloader lets you set the pressure to suit the task • Glycerin filled pressure gauge for reliable results • Multi-hour bypass and run-dry capability prolongs pump life Professional Grade Gun And Lance With Safety Screw Couplers • Knife-jet high pressure wash/soap nozzle cuts through grime • Dirt Killer turbo nozzle doubles cleaning power for tough jobs Exit Side Chemical Injection • Since detergents don't pass thru pump, better selection available • Includes 33' wire braid reinforced, 1/4" hose This should be updated on our site shortly.
Nice, always wanted a kranzle got to wait till my gas one goes poo I don't like gas pressure washers cause you got to start the them leave them on..... Super annoying. Electric one you can leave on and only make noise when you using them plus still way quieter than gas when in use
We just received out Kranzle Prosumer 1400 PSI (Electric-Cold Water) Pressure Washer K1120T and I got to say I love it! Its a smooth unit. It doesn't feel as strong as the cam spray but its 15 amp, and the creature comforts are exactly what I wanted. The cart, the hose reel, the 50 foot hose, and the best part the cam spray foam canon works perfect on it! This is truly a great prosumer product.
