What is the best way to remove water spots or some kind of liquid etched onto the paint? Products? Techniques? Secrets?
i tried using vinegar but had not luck. i put some on a towel and let it sit on the hood, but the spots were still there. how are you guys doing it? thanks
Might need to use an abrasive polish. Heres another option, http://www.valugard.net/cms/xramp/ValuGardNeutralizationSystem/tabid/84/Default.aspx
go to a local place that sells boats and see if they carry a product called "Ducky" water spot remover. I use this stuff on boats all the time and it's killer on removing water spots. However, if they've been sitting there for a while they may have etched into the paint and will require some polishing to remove the etching
I hear CG water spot remover is no good. I heard a lot about the DG 501. Think I'm gonna try that out.
Thanks.. but I'm just gonna live with it for now, its very minor. I'm sure once I get some Menz, it'll come off.
