Waterspots Everywhere
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by jtdigital, Nov 30, 2009.
  1. jtdigital
    jtdigital Virgin Detailer
    Ever since i got a xenon flashlight, I noticed waterspots under my headlights/tailights on the bumper and the lights itself. (Basically inbetwen sideskirts doorjams/bumper tailights/headlights/bumpers) Obviously I can't use a buffer because it won't fit, I can probaly squeeze a cuetip in there? What product should I use that is safe for both?
  2. kustomizingkid
    kustomizingkid Nuba Guru
    I would pick up some CG waterspot remover.
    Also if it were my car I'd remove the headlights and tail lights... easy to do...
  3. corrswitch
    corrswitch Jedi Nuba
    You can put away the new flashlight :)
    As I learn more and more, I find more and more things I want to do to my car :)
    However, I saw some of those polish pads that fit on a finger so you can finger polish that area.
    I'm trying to visualize it so I think that might be able to help. The same kind you use for under the door handles.
    I could be wrong cuz you said you could barely squeeze a qtip
  4. supercharged
    CG water spot remover rocks! Be sure to read and follow directions...
  5. Follmer
    Follmer Birth of a Detailer
    Will this remove deep water spots? On my roof Ive used DG 652 and I've clay bared the area and I still cant get these things out!
  6. richy
    Jason had an amazing thread on Danase water spot remover..I bought some based on that thread alone!
