Recently completed, this R32 needed some attention as it is a daily driver. First pic denotes correction on the clearfilm as it had marring and water spot etch. Certain parts of the vehicle had been re-sprayed, so what was not done by the body shop I and Daniel from Car Connoissuer in So.Cal made the defects go away for good. Before on the drivers door. After. More sand scratches. After. DA sand scratches under turn signal indicator. After. Yes there is more defects......................... Defects removed. Even more................................ "Certified tightness" now. Clearfilm on rocker has marring and water spot etch. Corrected. Hard to believe.................more sand scratches, the body shop who painted this car must have sanded and cut the car in th dark. Defects removed. Daniel even cleaned and dressed the wiper blades on the top side. Daniel working the interior, was not bad at all. A few sun shots.
