Vehicle Upholstery Cleaning and Care
Discussion in 'Interior Car Care' started by togwt, Jan 24, 2009.
  1. togwt
    All kinds of dust, fumes, smoke and dirt builds up inside of a cars interior, much of it is brought in by the driver and passengers, but traffic fumes and air-borne dirt enters via the vehicles ventilation system. Every single interior surface is affected. Periodically it needs to be thoroughly cleaned to remove pollutants and preserve the original surfaces, ensuring the vehicles like-new condition.
    To remove stains the surface tension that bonds them must be released, then the stain encapsulated and held in suspension to be removed. I’m repeatedly asked which product is the best interior cleaner. There is no one-product answer; as the so-called all purpose cleaners (APC) do not remove every stain, different stains require different solvents to remove them.
    The interior environment of an automobile can be extremely demanding on any material used. Temperatures range from hot dry summer days, to freezing nights. Both high and low humidity, even air conditioning that cools, but also dries. Upholstery’s greatest enemies are; sun, heat, body oils and ultra violet radiation (UVR), especially leather as it dries the hide, fades the colour by bleaching, and can cause the leather to fail by drying out the fibres causing the polyurethane and / or the hide to crack.
    Stains: The first thing you should do upon discovering a stain is to act immediately. Don’t wait because heat and/or time will just cause the stain to set in deeper, which will make it much harder to remove. Before deciding upon treatment, you should first access what ‘type’ of stain it is, before a stain can be removed the surface tension that bonds it must be released, then the stain encapsulated and held in suspension to be removed.
    Classifying stains-
    a) Organic stains- these include proteins and fats, body oils, mould yeast, bacteria, bugs and carbohydrates. Most of the stains found in the vehicle interior are of an organic nature and require an alkaline type cleaner. Some organic stains (i.e. blood, vomit, urine) should be removed with an enzyme type cleaner and a disinfectant applied to the area
    b) Non-Organic stains- mostly found on the exterior of the vehicle, hard water scale (calcium) lime deposits, Road tar, grease and oil film, and require an acidic type cleaner.
    c) Petroleum soils - substances that do not contain water, nor are they miscible, these soil types include, motor oils, and crease and road tar, and require a solvent type cleaner.
    Stain Types-
    a) Water Soluble Stains- These stains can be dissolved in cool water or loosened with water based cleaner, coffee; soft drinks, cocoa and chocolate are good examples.
    b) Oil soluble stains- These are stains that are comprised of oily or greasy substances, which include cooking, oil from fried foods and suntan oil.
    c) Combination Stains- These stains contain both water based and oil-soluble properties. Cleaning these stains require treatment with a petroleum solvent followed by water based cleaning solution.
    d) Unidentifiable Stains- Sometimes stains cannot be identified. Treat these stains like a combination stain. Clean with a petroleum solvent followed by water based cleaner.
    Always select a chemical / cleaner that are biodegradable, environmentally friendly and safe to use by observing any precautions recommended so that they won’t harm you, your vehicle or the environment
    Specific fabric stains-
    a) Red Stains- Try to find out the source of the stain (Koolaid, Gatorade, Red wine, etc.) It is important to know the source as many old coffee or tea stains can look like red dye stains and many stains if treated improperly can "set" and then be a major task to remove
    Removing Red Stains is one of the toughest to remove because usually a red food dye is used and if spilled on fabric or upholstery it will dye it. Use Red Stain Remover (topoftheline.com) is a unique formulation that removes super tough red stains. Spray the solution on the stain and agitated with a brush to make sure it has penetrated the fibre. Allow it to sit a few minutes to insure the chemical "action" dissolves the dye. Place a dry towel over the area and press with a hot iron, as the heat draws the dye to the towel so it can be lifted from the fabric. http://www.fabriclink.com/fabriccare.html
    The process may take a couple of applications especially if stain is old, or has been allowed to set for some time. Follow with a thorough hand-cleaning using Woolite® Heavy Traffic Carpet Cleaner), or with an extractor. Oncefabric is thoroughly dry protect it from future stains (using 303 Fabric Protector)
    b) Blood- remove the stain as soon as possible; if it sets it will be more difficult to remove. Once the stain has been removed the area should also be treated with a disinfectant (Lysol™ Disinfectant). Take all necessary precautions when dealing with blood (latex cloves, and etc) and when disposing of blood stained items.
    Wipe down the area with a damp micro fibre towel and then remove blood stains using a 2:1 solution cold distilled water / Hydrogen peroxide, this will eliminate the stain and provide a disinfectant.
    Finally rinse the area with a damp micro fibre towel. Take all necessary precautions when dealing with bodily fluid stains (latex cloves and etc) and when disposing of soiled items. (See Vehicle Interior Detailing Article)
    c) Wax (candle or crayon)- to remove melted wax from carpeting, place an absorbent paper towel folded 4-5 times over the wax and with a hot iron run it back and forth on the towel (renewing as required) this will re-liquefy the wax and the towel will absorb it. Repeat as necessary.
    d) Pet stains and odours- Enzyme is specially formulated using enzyme action to eliminate odours caused by pet urine vomit to digest the stains and odours left behind by pet urine and faeces. (PETsMART)
    e) Bituminous Asphalt Stain Removal-
    a)A solvent (Stoner™ Tarminator) can also dissolve a variety of oil and petroleum based products, it's safe to use on all types of paint, plastics, synthetic fibres, carpet and upholstery. If used on vehicle paintwork re-apply a protect rant after use. Something else you can try is isopropyl alcohol (IPA) using a sponge or towels gently blot until the stain is lifted. Blot again with cool water to rinse. Dry with a thick towel.
    b)A dry cleaning solvent will also remove asphalt, as with the alcohol, pour onto a sponge or cloth and blot. Keep blotting until the stain is lifted and then blot with cool water until all traces of the chemical is removed; blot dry with a thick towel.
    Different cleaning methods to remove two different types of contaminants
    1. Hot water and liquid soap to remove water-soluble contaminants:
    Dirt, Mud
    Road Salt
    2. Wax and Grease Remover to remove solvent soluble contaminants:
    Grease and Oil (Stoner’s Tarminator)
    Road Tar ditto
    Tree Sap ditto
    Bird Droppings ditto
    Wax and Polishes (DuPont Prepsol)
    With all cleaning products (especially solvents) always test a small inconspicuous area first to ensure it won't discolour, stain or etch the surface, and ensure that the pH of the product is suitable for the material After the paint surface has been subjected to a chemical cleaning its protective layer (s) have been removed and the paint surface left without protection, so it is very important that a wax or polymer protection be applied immediately.
    As can be seen stain removal requires some knowledge of basic chemistry. Read the product labels and manufacturers material safety data sheets (MSDS) to obtain a basic idea of contents, pH levels etc. Always select a chemical / cleaner that are biodegradable, environmentally friendly and safe to use by observing any precautions recommended so that they won’t harm you, your vehicle or the environment. (See also Vehicle Interior Detailing, Solvents)
    Before using a cleaning product a detailer needs to know the material they are working on, what they are trying to remove and wither the product chosen is compatible with the material and will not damage it. Diagnosis is the key, not guess work. With all cleaning products, always test a small, inconspicuous area first to ensure it won't discolour or stain the surface, and ensure that the pH of the product is suitable for the material. As can be seen stain removal requires some knowledge of basic chemistry. Read the product labels and manufacturers safety data sheets (MSDS) to obtain a basic idea of contents, pH levels etc.
    Using dry steam vapour
    A system that produces a high temperature, low moisture vapour that contains only 5% to 6% water and is much less dense than air, a steam vapour system is equipped to safely produce thousands of gallons of live dry steam using only about 1.5 quarts of water per hour. It is mess free with temperatures hot enough to kill bacteria and germs, emulsify grease and oil as well as other surface contaminants. These units are best suited for light cleaning (covered leather or fabric upholstery) maintenance, and spot removal. Apply a cleaner to a sponge, work up foam and apply to the surface, then pass the steamer just above the top of the area just cleaned and lightly agitate with a micro fibre towel, then wipe dry. Steam vapour helps to emulsify the grime, while the foam encapsulates it. Steam when it cools turns to condensate (water) which helps to re-hydrate the hide
    Using an Extractor System
    An extraction system process is the choice of professional detailers due to its cost effectiveness, performance efficiency and time saving over conventional methods. Extractors work by using a cleaning solution dispensed from a tank that heats the solution to 200oF+ and is sprayed at medium pressure (50 PSI +) and a high volume from the machine via a cleaning wand; it is then filtered and re-circulated.
    The water is heated and pressurized, which produces a dry vapour. When the vapour leaves the nozzle it is then subjected to atmospheric pressure and expands (a phase change), vapour micro-molecules are able to penetrate the pores on any permeable surface. When the molecules come in contact with a surface they expand forcing any dirt, debris, and bacteria to the surface (steam vapour also kills bacteria) Dry vapour has a water content of about 5%, so the surface dries extremely quickly
    Extraction also allows the ability to remove cleaning residues due to its high suction power (100-inch water gauge +). Rinsed fabrics look and smell cleaner and resist soiling better. I know ‘lesser’ machines may give the appearance of a clean interior, but in reality, the soil is being migrated the bottom of the carpet, this dampened soil will cause mould / mildew formation as the suction lift on lesser machines is pretty much non-existent. Mould uses enzymes to digest nutrients from organic materials, the mould forms on top of the material and also down into its fibres leaving circular or black spots in an irregular pattern Dirt and moisture are essential to mildew propagation.
    Pre-cleaner- a) Organic stain removal- quarter (1/4) cup Protein Stain Remover (topoftheline.com) / 1-cup 303™ Cleaner & Spot Remover / one gallon hot water let dwell for 5-10 minutes to enable cleaners to react
    b) Other stain removal- 10:1 distilled hot water/ P21S Total Auto Wash, let solution dwell for 5-10 minutes to enable cleaners to react
    Methodology
    •Use a rubber bristle brush to go over the material to raise the fibres
    •Vacuum area very thoroughly (Metro Vac N' Blo®) to lift all the loose dirt from the carpet Remove any stains with 303™ Spot Remover & Cleaner
    •Spot treat really bad stains (303TM Cleaner & Spot Remover)
    •Use a pre-cleaner solution, 10:1 distilled hot water/ P21S Total Auto Wash, let solution dwell for 5-10 minutes to enable cleaners to react
    •After sufficient dwell time agitate pre cleaner solution with an upholstery brush to ‘scrub’ surfaces
    •Use an extractor to clean and remove liquid and dirt. (Vapour Clean Products T5 Extractor / Spotter®)
    •Use a 16:1 solution clean distilled hot water 303™ Cleaner & Spot Remover
    •Use a rubber bristle brush go over the material to raise the fibres
    •The next step would be to use its high-volume vacuum, in one direction only (do not scrub) to remove the excess moisture and grime, immediately recovering it.
    •Allow to thoroughly dry before use
    •Once fabric is dry apply a fabric protection (303TM High Tech Fabric Guard)
    Notes:
    1. Use the hottest water available it also helps to pre-spray the carpet with hot water when hand cleaning carpets / mats
    2. Run a 2:1 solution distilled water / distilled white vinegar thru the extractor either weekly, or after every ten fresh fills. Vinegar, contains Acetic acid, an organic carboxylic that will help eliminate scale, mild mineral deposits etc. from clogging your extractor.
    3. Odour removal- add 4 ounces Door Terminator to each gallon of extractor solution. Clean interior glass after use to prevent spotting. (Automotive International - Valugard
    Upholstery and Trim Surface Identification
    It is important to be able to recognise the different materials used for vehicle upholstery as some OEM use different materials for the various surfaces; steering wheel, dashboard, sport seats, seating surfaces (bolster, seating area, seat backs, head restraints, etc) door panels and even the roof lining. Before choosing a product to clean or maintain interior surfaces you must be certain of the material used as the correct product requirements are vastly different.
    (a)Protected leather (covered) - by slightly scratching it with your nail, if it changes to a darker / lighter shade, it is unprotected (i.e. how suede changes colour depending on the fibres' orientation). If this has little effect it’s protected. If water ‘beads’ on the surface, then it is probably covered leather. If it soaks in, then it is probably finished leather
    (b)Natural leather (uncovered) Has a random shade colours and grain pattern; lightly scratch the surface to see if it reveals a lighter colour, water drops will darken its colour (temporarily).
    (c)Nubuck, Alcantara®- are top-grain cattle hide leather that has been sanded or buffed on the grain side, or outside, to give a slight nap of short protein fibres, producing a velvet-like surface. It is very soft to the touch will scratch or scuff very easily; water drops will darken the leather but it returns to its original colour after drying.
    (d)Vinyl - will have a much more even, almost repeating pattern. The depth of the lines within the grain on vinyl is also consistent, while the same lines on leather will vary; it is also usually smooth and soft to the touch.
    Fabric Seat Cleaning:
    1. Cleaning- Use a soft brush to remove any surface dust, the next step is to clean the fabric by spraying 303™ Cleaner & Spot Remover until damp; this product may be used on all water safe materials. The cleaning action increases with warm water, agitation and longer dwell time. Completely wipe away dirt/grime with damp cloth until clean, rinsing out towel in clean warm water as required, allow to completely dry before use.
    2. Conditioning and Protecting- Don't miss this very important step. Once your interior is clean and completely dry you should use a conditioning/protection product (303™ High Tech Fabric Guard, which includes UVR protection or Scotchgard™ Carpet Protector) to ensure protected surface will repel dirt and moisture, and again, keep your vehicle in its like-new condition It is very important to ensure that the fabric upholstery is very thoroughly rinsed, as the cleaners will pull (wick) the dirt to the surface. The soap and oils will attract dirt and oily grime like a magnet (re-soiling) if they are not thoroughly rinsed away giving the appearance that they have not been cleaned.
    3. Ultra Violet Protection (Maintenance) - Select a product (303™ Aerospace Protectant) that contains UVR protection for maximum fade protection, a must for convertibles.
    Fabric Upholstery Protection – 303™ High Tech Fabric Guard, 3M Scotchgard™ Fabric protector fluorocarbon chemicals (polymer latex) are mostly inert so by applying it to fabric (not for use on automotive leather upholstery, see Leather Protection) it can be protected from stains and soiling.
    Fluorocarbons are a class of molecules that possess a variety of unique and economically valuable properties. Molecules that contain multiple carbon-fluorine bonds are chemically and thermally stable, with high dielectric strengths. Fluorocarbons are lipophobic (non-absorbent) in addition to being hydrophobic/non-polar, finding applications as oil, water, and stain repellents.
    Information resource-
    Automotive Detailing Inside & Out, A Knowledge Base for the Perfectionist– by Jon Miller
    © TOGWT ™ Ltd Copyright 2002-2008, all rights reserved
    Copyright and intellectual property rights-© This work is registered with the UK Copyright Service All original material is copyright, unless otherwise state (1) it may be copied and distributed for non-commercial purposes only provided that you retain all copyright and other proprietary notices contained in the original material, (2) the information is copied in full with no changes unless prior written agreement is obtained from TOGWT, and a reference to © TOGWT ™ is included, any unauthorized use of these materials may violate copyrights and/or trademarks ( P-02: Protecting Copyright - Information Fact Sheet)
  2. blk45
    blk45 Jedi Nuba
    Great info as usual. Thank you!
  3. BrendanS
    BrendanS Welcome to Detailing
    Great post, thanks for the study break!
  4. E-Money
    E-Money Birth of a Detailer
    :applause2:
