Basically I need something thats about as cost effective as Megs wheel brightener yet as safe to use as the P21s gel. Does anyone know if Valugards custom wheel cleaner is pH neutral and wont harm any wheel surface or braking system? Product Details from Autoint. Designed specifically for today's factory clear coated wheels. Custom Wheel will not cause coatings to peel or degrade. It's non hydrofluoric, high foaming formula provides extra vertical cling, allowing it to work longer. (And allowing the technician to work less). Safe for all steel, painted and coated wheels, it removes brake dust and road grime.
Check mobileworks, Ron should have some info on the product. Believe it is super safe like all their products.
