Using a DQ to aid in drying
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Reflect, Jan 15, 2009.
  1. Reflect
    I've heard more recently than before that people are using QD as a means to aid drying. Can someone elaborate on their system?:chips:
  2. Denzil
    I just spray as I wipe dry to help lubricate and add insurance to avoid any MF-induced marring, if it should happen.
  3. Reflect
    Does it also help prevent water spots?
  4. pektel
    pektel DB Forum Supporter
    I find the surface becomes completely dry faster than if I were to not use the QD. but I also have hard water where I live, so my results may differ.
  5. pektel
    My method is simply to mist before I touch the surface with my WW MF. It seems to really speed up the drying process, since it - for me - seems to help the mf absorb the moisture faster.
  6. slanguage
    I mist the area right before drying it also. Might help some in reducing water spots, but that's also the point of drying the car, isn't it? :D
  7. krshultz
    krshultz Nuba Guru
    I do this sometimes, but not until I've passed over the vehicle once with drying towels. To spray QD all over a wet vehicle seems, to me, a bit wasteful - like you're diluting the QD as a result of spraying it onto all that water. Usually, if it's a "normal sized" vehicle, I do this:
    - One pass with a large MF drying towel
    - Second pass with a second large MF drying towel plus QD
    I should also mention that this is just what I do with my own vehicles. If I'm doing one for a customer, I know I'll be claying after the wash, so I don't bother with the QD. Seems wasteful to me.
  8. budman3
    budman3 Birth of a Detailer
    Has anyone noticed drying with a QD tends to clog WW MF towels reducing their effectiveness over time?
    I like the thought of drying with added precautions and lubrication from a QD but don't want to ruin the WWs over time. Maybe boiling the towels could recover the effectiveness?
  9. infinity
    infinity Any Rag Vehicle Washer
    give this a try, it work for me,
    after rinsing spray a fine mist over the car then towel dry, i use procedure on a regular basis with good
    results.
  10. Dust2Glory
    Dust2Glory Nuba Guru
    I do this on EVERY vehicle.... i basically spray the vehicle down with QD while wet, especially the windows... prevents water spots and helps to loosed the water out of cracks.
    And most times I also mist the drying towels with QD as well to help drying.
    And it has not ruined any of my drying towels to date. Most QD's you can dilute 1:1 which i do...
  11. supercharged
    using DQ??? whatta? Must be dillutiable BBQ sause to use a drying aid or something...:poke:
    Sorry, I just had to go there when I saw this topic...:applause2:
  12. Reflect
    Wow, I'm an idiot! Of course you can't use Dairy Queen to dry a car.:shead:
  13. supercharged
    LOL! That was a good one...it's OK, everyone makes mistakes.
