Updated the inside of my van
Discussion in 'Show and Shine' started by kakeuter, Sep 4, 2012.
  1. kakeuter
    kakeuter DB Forum Supporter
    So I’ve been slacking on posting any work lately, business is crazy busy. I have had my van for about 10 months and last weekend I decided to change up the inside to better accommodate my process.
    I use to have a 100-gallon tank, I didn’t like the way it looked and to be honest I do NOT need to haul that much water anymore. So I decided to downsize the tank and change the layout.
    Here is what it looked like.
    Don’t get me wrong, it worked great, but the water pump leaked a little bit and the hose reel wasn’t in the most optimal position.
    So I ordered the 60-gallon tank and bought a better water pump. Here are the finished results.
    Still got the bottles on the back doors, but now they are labeled.
    Driver’s side of back end.
    Passenger’s side: the hose that is hung up is for filling buckets, it’s hooked up the water pump and has a shutoff valve on it so there’s no hooking up and unhooking every time I need to fill a bucket.
    Shot from behind the tank.
    Shot of the tank/hose reel/shadow board
    Close-up of shadow board
    Shot of everything
    All in all it works great. I wired in a switched and mounted it on the right-hand door jamb area (you can see it in the pic of the pressure washer). There’s no leaks, the water pump is silent and actually kicks off when water is not flowing when the switch is on (like when I’m not squeezing the pressure washer trigger).
    Thanks for viewing!
    -Kody-
  2. vtec92civic
    vtec92civic Nuba Guru
    Damn cody that is one hell of a sweet setup man. Lovin it especially because i have the same van. You gave me some good ideas. LoL
  3. boredstudent3
    boredstudent3 Wax on..Wax off
    kody,
    that looks great man!
    i like the idea with the shadow board, it helps keep everything in place and sturdy, genius idea! you could pack a whole bunch of brushes and small items into that large board and nothing will fall out.
    what's on the back wall (i.e. dividing wall behind the driver's seat)?
  4. kakeuter
    Thanks for the compliment. On the steel wall behind the front seats are 6 more of the baskets (but not white), 3 on each side. The passenger side ones hold towels and the driver side trio hold more chemicals/polishes.
    I still plan to mount more stuff to the passenger side pegboard, it use to hold my husky shop light, but took it down b/c I hardly work at night. I only want to utilize the space for stuff I need to use, otherwise it just gets too busy rather than making me more efficient.
    -Kody-
  5. 911Fanatic
    Looks Good!
  6. Pureshine
    Pureshine DB Pro Supporter
    Wow that looks great nice job on the van.
  7. Auto Concierge
    I like the foam cut-out for your brushes.....................certified tightness level of equipment. Do the bottles on the rear door ever come loose and leak? if they do you might want to convert to baskets like on the inside even if there is more noise when driving around.
  8. kakeuter
    Thanks Ken!
    Thank you!
    Thanks Bob. No, I haven't had any problems with the bottles on the rear door, they've been solid as a rock ever since I installed them (thankfully). I would highly recommend these spring loaded hangers to anyone.
  9. GDAL
    GDAL Super Moderator
    Great layout ... love the foam cut out board!
  10. vtec92civic
    thanks for the photo buddy . . . . i received it.
  11. Andy6228
    Andy6228 Birth of a Detailer
    Great job!. It's clear that you have put some time and effort into you set up.
  12. React
    React Birth of a Detailer
    Great setup. Thanks for sharing
  13. kakeuter
    Thanks guys! I'm loving the new setup, works flawlessly.
    -Kody-
  14. stottie
    stottie Birth of a Detailer
    awsome set up. really like the smaller water tank instead of the big one. how does your set up work with the power washer? is it a pump that pulls water out of the tank and generates power to the nozzel? thanks
  15. vtec92civic
    If you look in the photo that shows behind the tank there is a small electric pump i believe. It sucks the water or pushes water from the tank to the blue electric pressure washer which the nozzle is run too. Pretty nice setup actually. Makes me want to try that out.
  16. kakeuter
    Correct. It's a 12 volt water pump that pulls water out of the tank into a "Y", one hose goes behind the peg board and connects to the back of the pressure washer. the other hose goes along the wheel well and is hung up behind the pressure washer, this hose is used for filling up buckets.
  17. stottie
    Thanks for the info I really like that set up. How do you power the pump and pressure washer? Do u use a generator or some ones electric?
  18. kakeuter
    The water pump is 12 volts so its ran off the vehicle battery and is wired to a switch mounted in the back right door jamb area by the pressure washer. Pressure washer is typically run off customer electricity, but if that's not available then I always carry a Honda eu2000i generator.
    -Kody-
