Understanding Foam Gun Ratios
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Denzil, Jul 9, 2008.
  1. Denzil
    Since Gemini suggested that we have a thread dedicated to foam gun ratios, I figured I'd volunteer my time for it (hey I'm on summer break and I love helping everyone at DB). However, I'll only be offering what I know for my Gilmour Foamaster II #95QGFMR.
    The particular Gilmour model I have has a multi-ratio dial with 5 mixing head settings. All these settings/specifications can be seen at the Gilmour website for your own personal reference.
    The most common used setting, at least for me anyways, has always been the C setting with an output volume of 4 oz./gal. In most cases car wash shampoos suggest having 1 oz of car wash shampoo added for every gallon of water. Initially you might ask, why not just keep it simple and use the A setting where its output volume is 1 oz./gal? The answer is the foam gun is not capable of sucking such a viscous liquid through its siphon tube. Now I can not attest to whether this is true or not but I don't dare try it myself. However, there is the exception with some of those cheaper car wash shampoos in which they are pretty watery (and probably not great car wash shampoos altogether).
    There's also the B setting (2 oz./gal.) which can be used as well but just remember that your shampoo mixture may still be too viscous for the foam gun to handle. One nice thing about the B setting though is that you will not be required to refill as often as you would as the C, D, or E settings.
    Since I mentioned the D and E settings, I will say that these settings are definitely not ideal. Their output flow, 6 oz./gal. and 12 oz./gal. respectively, is just too fast and will require a lot of refilling! For me, these are simply not an option almost all the time but perhaps maybe it is for others. I won't even bother with the E setting as it's just not practical for me but I will mention the one occasion in which the D setting is actually useful later. Anyway, on to the hard numbers!
    We'll start with the most common dilution, 1 oz of car wash shampoo to 1 gallon of water. The 95GQFMR is a quart container which is the equivalent of 32 oz. At the C setting, we have an output flow of 4 oz./gal. Now in essence, we want 1 oz of that 4 oz./gal. flow to be car wash shampoo and in order to achieve that, we must have a 3:1 ratio in the 95GFQFMR container. So how do you do that? It's pretty simple. You add 8 oz of car wash shampoo and 24 oz of water so that your ratio comes out to 3:1. So what if you want to use the B setting? Sure, that can be done. Your ratio will then effectively be 2:2 or 1:1 and you will be adding 16 oz of car wash shampoo and 16 oz of water. The only concern with using the B setting is whether or not your mixed solution will be soluble enough to be sucked up through the siphon tube and provide the proper volume output. Of course as I mentioned before, the B setting will require less refilling than using the C setting which is nice.
    Ok, so what about car wash shampoos such as Chemical Guys Citrus Wash & Gloss? Well, they have 2 different dilutions for separate applications. There is one dilution that is ideal for the weekly wash in which 1/2 oz of CWG is required for every 2 gallons of water or 1/4 oz of CWG for every gallon of water. There's also the paint cleanser dilution which is 2 oz of CWG for every gallon of water.
    In order to achieve the proper dilution for CWG as a weekly wash, we need 1/4 oz of car wash shampoo for every gallon of water. Now this gets a little tricky with the 95QGFMR and I may lose you in its translation. Since our previous dilutions have been 1 oz of car wash shampoo to 1 gallon of water, we need to figure out what setting we'll be using before we dive further into the numbers.
    If we want to go with the most common C setting, the short answer is we divide by 4. Now if we divide our original 8 oz of car wash shampoo by 4, that gives us 2 oz of car wash shampoo and leaves us with the remaining 30 oz of the 95QGFMR to be filled with water. To fully understand how this calculates out, we have to remember that at the C setting we are outputting at a rate of 4 oz./gal and we want 1/4 oz./gal. If you think about it, 2 oz of car wash shampoo to 30 oz of water is simply 30:2 or 15:1. However, we are still at a ratio to 1 and what we really want is to 1/4 or .25 in order to understand the numbers in a simpler form. To keep it fairly simple, we divide both sides of the ratio (15:1) by 4 which gives us 3.75:.25. Well what do you know, these two numbers add up to a total of 4, meaning 4 oz, which also meets our requirement of 4 oz./gal. output flow.
    So what if you want to use the B setting? It's pretty simple. Just use 4 oz of CWG and 28 oz of water, with the ratios working out as follows (keep in mind these are all equivalents): 28:4 -> 14:2 -> 7:1 -> 3.5:.5. -> 1.75:.25.
    Okay, now that's out of the way. What if you want to use it as a paintwork cleanser? So it's 2 oz of car wash shampoo to 1 gallon of water. Ok, simple enough but it's doubtful that you'll be using the B setting for this one. Essentially if you do decide to use the B setting you'll have to fill the entire container with solid CWG, non-diluted. As I mentioned before, the 95GQFMR will not be likely to successfully suck this viscous liquid through it's siphon tube. So C setting it is and it's simple. You need 2 oz of car wash shampoo for every gallon of water and at the C setting we have an output flow of 4 oz./gal. Essentially, we just need a 1:1 ratio here, 16 oz of CWG and 16 oz of water. Now if that mixture may be too viscous still (I haven't tried it myself yet), this would probably be the only occasion in which the D setting would be feasible, IMO. At the D setting we have an output flow of 6 oz./gal. which would mean that in order to achieve a 2 oz of car wash shampoo for every gallon of water, we'd need a 2:1 ratio, which roughly comes out to 11 oz of CWG and 21 oz of water (the ratio isn't exactly 2:1).
    Ok so that was a lot of reading (if some of you actually read it all) but below you will find the short and sweet version for your reference. I'll continue to add to it if need be. I hope my English was structured well enough to understand, LoL. Either way, I hope it helps out some of the fellow foam gun users who are still new to its dilution ratios or just need some refreshing of their memory. Enjoy!
    Gilmour Foamaster II #95GQFMR
    Any car wash soap at 1 oz per gallon of water
    C setting -
    8 oz of any car wash soap + 24 oz of water
    B setting - 16 oz of any car wash soap + 16 oz of water
    Chemical Guys Citrus Wash & Gloss at 1/4 oz per gallon of water (weekly wash), also applies to Citrus Wash & Clear and Maxi Suds II
    C setting - 2 oz of CWG/CWC/MSII + 30 oz of water
    B setting - 4 oz of CWG/CWC/MSII + 28 oz of water
    Chemical Guys Citrus Wash & Gloss at 2 oz per gallon of water (paintwork cleanser)
    C setting - 16 oz of CWG + 16 oz of water
    D setting - 11 oz CWG + 21 oz of water
    Detailer's Pride Xtreme Foam at .4 oz per gallon of water
    C setting - 3.2 oz of DPXF + 28.8 oz of water
    B setting - 6.4 oz of DPXF + 25.6 oz of water
    Detailer's Pride Xtreme Foam at .5 oz per gallon of water (for simplicity and/or rounder numbers)
    C setting - 4 oz of DPXF + 28 oz of water
    B setting - 8 oz of DPXF + 24 oz of water
  2. SuperBee364
    SuperBee364 Birth of a Detailer
    OK, now that's just too cool. That's gonna save alot of people alot of work.
  3. Mindflux
    Mindflux Welcome to Detailing
    Great writeup Denzil.
    There was a writeup on DU regarding this exact same thing.
    This is for a 64oz tank, so just cut these figures in half.
  4. Denzil
    Oh nice! I wasn't even aware that existed, LoL. I was thinking of doing a table but I got lazy, haha. Oh I noticed that for their non-stripping they decided to use a 1/2 oz per gallon instead of the 1/4 oz per gallon that I had suggested. I wonder if that even makes a difference at all?
  5. detaildoc
    detaildoc Guest
    Cool! Very helpful
  6. zspectrum
    zspectrum Jedi Nuba
    so if im using the c setting how much maxi suds II/ water do I add into the quart container of my foam cannon. Same question for citrus wash clear. if were using the same gun you are.
  7. Nica
    Nice thread :thumb:
  8. Pats300zx
    Great post...
    Here are the ratios for those with the old Foamaster..
    5 settings to fit your various needs
    1/128 1-64 1-32 1-20 1-10
    1 oz./gal. 2 oz./gal. 4 oz./gal. 6 oz./gal. 12 oz./gal.
    Any one know if its left to right or right to left?
    I always use mine with one hold showing on the right.
  9. supercharged
    great price on it there!!!
  10. Gemini13
    Gemini13 Obsessive Detailer
    NYCE!!!!!!!!!!!! :D Great idea by myself I just lack the time.
  11. sal329
    sal329 Nuba Guru
    Bookmarked for the some day I get my foam gun
  12. Smith2287
    Nice thread guys when I use my foam gun I normally use the highest setting or the second to last one. I dont think I ever put the proper ratios in the thing as I would normally just to about an once of soap and fill the 32 oz container up. I still don't get to the same amount of suds as I see you guys using it in your write ups. I am going to try only half an once of soap with less water tomorrow and see what I can do. Thanks again for all the good info :headbang:
  13. MadOzodi
    MadOzodi Nuba Guru
    One hole showing to the right would be 1-32 or 4oz/gal. Also, it's left to right. When you look at the top of the old FM from above, you'll see a small circle to the left of the screw on top, with the output pointing away from you. Within that is a ball bearing and spring. The rod that you twist and move from left to right actually has 6 holes total, with the first hole there just to lock the rod in the first position to achieve 1/128 or 1oz/gal.
    And yes, I'm typing this with it right in front of me cuz I'm :crasy: like that.
  14. Denzil
    I'm glad this has been helpful for some of you! In fact, I'm bookmarking this myself so I don't forget either (because knowing me I will forget too)!
    I'm curious but is CWG the only car wash shampoo that has these really conservative dilution ratios for weekly washing? I'm under the assumption that every other car wash shampoo follows the 1 oz per gallon guideline.
  15. MadOzodi
    MadOzodi Nuba Guru
    Whoops, forgot to give you a big :thumb: for taking the time to post this Denz. I think DG901 is another one that doesn't follow the 1oz/gallon dilution, as well as DP Xtreme foam. I know Optimum Car Wash is 1oz/gallon and I believe PBSSS is also. Heading downstairs to put the old FoamMaster back and check on the dilution ratios of the car wash shampoos I gotz...
    Ok, the Adams isn't very clear but I assume it's less than 1oz/gallon...directions say 1oz on the wash pad, fill up bucket 2/3 full of water.
    For the DP Xtreme Foam in a bucket, it's 2-3oz per 5 gallons of H2O.
    Valugard "C" wash is also 1oz/gallon.
    I have no idea how the *bleep* I ended up with so many car wash shampoos.
  16. Denzil
    LoL, yeah the Adam's does seem a bit unclear. Anyway, I'll add the DP Xtreme Foam to the list. I'll go with the conservative dilution of 2 oz per 5 gallons of water. That leaves us with .4 oz./gal. I'll update the original post. Thanks!
    I also decided to include a dilution of 2.5 oz per 5 gallons of water or .5 oz./gal. for simplicity and rounder numbers.
  17. zspectrum
    zspectrum Jedi Nuba
    can we add maxi suds II and citrus wash clear to the list?
  18. Denzil
    You'll have to inform me what their directions are because I have no idea what they are and what dilutions/ratios they suggest. Thanks.
  19. zspectrum
    zspectrum Jedi Nuba
    maxi suds II is one capful per gallon and each capful is about a 1/4 ounce so 1 ounce per 4 gallons?
    citrus wash clear is the same as the citrus wash and gloss.
    Thanks man.
  20. MadOzodi
    MadOzodi Nuba Guru
    Isn't Maxi Suds II the same thing as Adam's? :shrug:
