Can I use the Uber Foam pads on my Griots Garage 6" Random Orbital and if so what size pad should I use? Thanks, Alex
I'm assuming you're asking about the 5.5 inch pads. If so, I would say probably no. According to Griot's, it's a 6" backing plate on it. If you're pads are 6.5", you're good to go.
You can get them from any vendor that sells DA backing plates, prices are about the same across the board.
