Top Inspection as a QD?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by domino, Nov 15, 2010.
  1. domino
    domino Welcome to Detailing
    Hi guys
    Atm my car is still wearing a coat of naviwax dark and it's holding up extremely well. Its the best wax ive used to date in durability and maintaining its look, and hasnt left any water spotting through record spring rainfall and 30 degree celsius days
    However, i have pin souveran and im itching to see how it looks, and if it can add anything to the look
    Im looking through my QDs and cant really see one i can use after a wash to clean the paint and not leave behind any wax or polymers.
    So was thinking about using my Top Inspection. From what ive read its designed to be used during correction stage to remove polishing oils, so does it contain a percentage of alcohol?
    I bought off a local detailer a spray with 15% alochol but i think that may be too harsh and damage the coat of naviwax?
  2. kyoshiro
    kyoshiro DB Forum Supporter
    doesnt top inspection also strip LSPs?
  3. Legacy99
    Legacy99 Wax on..Wax off
    If you want to get the true look of Souveran, why not remove the Naviwax? You can always re-apply if you don't like the Souveran. Souveran won't last more than a month anyway.
  4. dsms
    dsms DB Forum Supporter
    Souv. From what I'm told really stands out on deep reds and blues. Your car is non metallic black wearing a wax that is specifically designed for black finishes. I don't think your going to benefit from adding souv on top or applying it alone at all.
  5. domino
    i know, but i have more carnaubas than fortnights in the year, and i have to test them somehow :shead:
    im really enjoying this naviwax as a base coat, its working really well in protecting the paint, better even than 476s
  6. JonM
    JonM Guest
    Souveran was designed for all dark colors, including black. Looked awesome on the S5, but didn't last long. For you that seems optimal as you change LSP's like I change jeans lol.
  7. domino
    as long as theyre not skinny leg mate :catfight:
    the "lack of" durability in souveran is why i thought its a good opportunity to test it out with naviwax as my base coat, and given ill be doing a full correction over the holidays when i get my new spanking wheels
    the only thing is, because ive let my car go 3-4 weeks in between washes, i want to run over it with a QD before applying the souveran, and one that doesnt leave any gloss enhancers etc, so i can see the true finish
    and this has steered me towards using Top Inspection
