Owner just wanted a good wash and seal so I thought I would play around with Optimum MF Cutting pads and some GPS. Even though it's intended for correction purposes I have found that the 2 can be used with some success at minor correction. Well this was a sure surprise! There was marring and light RIDS on the car but after 1 pass with the FLEX it removed almost all the defects! Owner was so happy that he Opted for the upgrade from Opti-seal to Opti-Coat! Car is pretty much a garage queen and doesn't get much thrashing anymore. Basic clean-up on the interior. Top was very dry and needed protection. Sonax on the wheels Dawn wash before polish Raggtop protectant Flex OPT MF GPS ONR wash Opti-Coat Perl on the tires and wheel wells
Great work ... looks amazing!! I really like Poliseal, but I find that it's almost impossible to completely remove from pads. IMO, poliseal looks a little bit better than GPS, but GPS is super easy to use and remove from pads. I usually add a small drop of OPT polish II to increase the cut.
