The best tire dressing
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Reflect, Nov 4, 2008.
  1. Reflect
    I'm looking for a mid to high gloss tire shine that is dry to the touch. Does such a unicorn exist?
  2. Cooter
    Are you looking for a water based product or solvent based??
  3. Jimmie
    Jimmie Birth of a Detailer
    DP Gloss Tire Gel.
  4. Reflect
    Whatever is drier.
  5. Niyo
    Niyo Virgin Detailer
    Wolfgang Black Diamond Tire Gel gets my vote.
  6. PhoTuGo
    PhoTuGo Jedi Nuba
    CG VRP :thumb:
  7. Cooter
    Adam's VRT
  8. POPPAJ
    POPPAJ DB Forum Supporter
    Optimum tire gel!
  9. MWAUTOPRO
    MWAUTOPRO Jedi Nuba
    Cg vrp
  10. P1et
    Adam's VRT. I have Optimum Opti-bond as well, but don't like it as much. I often get uneven application, which pisses me off.
  11. Reflect
    LOL. Ok so it looks like the general trend say it's actually best to go with a multi-use dressing. Which one is it, CG or Adam's?
  12. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Optimum Tire bond
  13. bryansbestwax
    Optigel or CG Liquid extreme shine
  14. bigpoppa
    bigpoppa Jedi Nuba
    I've been using Armor All Original exclusively for the last year or so and couldn't be happier. The perfect look IMO, water based, and when used with the proper applicator only requires 1 or 2 coats to get it 100% uniform (even on dry tires).
  15. Dust2Glory
    Dust2Glory Nuba Guru
    VRT and VRP r the same thing... I like Meg's Hyper Dressing because you can control the gloss
  16. Cleaning Fool
    Cleaning Fool Birth of a Detailer
    Ive pretty much had it with water based dressings. Im going solvent based soon, piss on it.
  17. slanguage
    when you use hyper dressing on tires, what dilution ratio do you use. I have some mixed 4:1 for engines and wells, and I like the look.
    Also, do you just spray it on the tires and let it dry, or buff it off after x amount of time?
  18. Dust2Glory
    I use it 1:1 on tires, I use a short handle body brush... the one with the green bristles. Spray a few times on the brush then onto the tire! works great!
    When I'm all done with the detail, I usually look over the tires and if I see something that looks like run, then I'll usually pat dry the tire
  19. Reflect
    How dry will these products become? As in no greasy feeling to them?
  20. P1et
    CG or Adam's, pretty much same thing. I bought mine from Phil at Detailers Domain under the Adam's brand.
