Just got my facebook20 order, haha! Close to $400 worth. Can't wait to try the Swissvax Concorso that I got! It's my first high end wax. Still kinda can't believe I spent that much money on wax so I sure hope I notice a difference, but I am very excited at the same time. Thanks, Phil!
ian, awesome, just make sure you prep the car correctly and you should be good. ken anytime hit me up...
Thanks 911fanatic! Phil, I also got the Swissvax cleaner fluid with my order and there is no way I would put this wax on any car without a full paint correction 1st! So since I keep my car realy clean I might hit it with a clay bar 1st, then either a coat of Collinite insulator wax then a coat of the Concorso or the cleaner fluid then concorso. I would like to see how it holds up to CT. winter weather without the help of collinite. Now if I could just find the time to do that, haha Thanks again! Ian
Ian, Do me a favor, if your car is perfect do the clay, do the cf then do the concorso, don't do the collinite I think you will be happy without topping it, (do straight SV CF/Concorso on one panel to see if you like it)
Ok, I'll give that try 1st. How should I apply the cleaner fliud? I was going to use my PC with either your blue or black padm also the Concorso says to use your palms to apply but my hands are way to ruff. A wax applicator pad should be fine right? I don't need to warm it up or anything just apply it like regular wax just want to make sure I do this the best way Thanks.Ian
what i did as my winter prep was use the p/c with a soft black pad and c/f . then topped with concorso . and the results were fantastic...
