Teasers on a few new items to look out for us..
Discussion in 'Detailers Domain' started by detailersdomain, May 6, 2009.
  1. detailersdomain
    Take a look at some of the new items we will have....
    Rapid Reel Hose Reel
    2-Wheel Cart
    Price: $179.95
    When portability is a must!
    This popular model is ideal for those who want durability AND portability. A rugged frame and wide wheel base make this model extremely stable and tip-resistant, allowing the reel to be elevated to a comfortable, back-saving height for easy rewinding. The innovative balanced design delivers ultra-easy mobility. NOTE: Hose and spray nozzle pictured are not included .
    Specs:
    Model.....................1043-GH Max. Temperature...............140°F
    5/8" Capacity.........150 feet * Max. Pressure.....................100 PSI
    3/4" Capacity.........100 feet * Shipping Weight..................35 lbs.
    *NOTE: Hose capacities may vary depending on hose brand & style.
    Features:
    EASY WINTER-FREEZE REPAIR
    Oops. Forgot to winterize the reel? No problem. These are not disposable reels and were designed for quick and easy repair. In fact, the entire plumbing, (hose & swivel), can be replaced in just seconds using no tools!
    FLAT FREE TIRES
    Eliminates the frustration of flat tires for good! Large, foam-filled, 10" rubber tires provide smooth and easy mobility.
    SMOOTH-SPIN AXLE BUSHINGS
    Positioned between the reel and the axle, these maintenance-free bushings not only allow the hose to pull out and rewind effortlessly, but will keep the reel spinning smoothly for years.
    10-YEAR WARRANTY
    The only garden hose reels on the market backed by a 10-year NO-leak, NO-rust and NO-break factory guarantee.
    DURABLE, POWDER-COAT FINISH
    Our extreme-duty paint resists fading and stays attractive for years. The neutral bronze color looks great with virtually any color of siding, brick, stucco, stone or wood.
    COMFORT-GRIP CRANK HANDLE
    This solid, full-palm design spins freely on a stainless steel shaft for effortless rewinding. Made from a high-impact material, it’s virtually unbreakable.
    LEAK-PROOF BRASS SWIVEL
    The exclusive and revolutionary design of this solid brass swivel features 3/4" flow capacity and a 10-year, no-leak guarantee.
    RUST-PROOF, METAL CONSTRUCTION
    Rugged, cast aluminum with stainless steel hardware and brass fittings provide unmatched durability for almost any application.
    150-FT HOSE CAPACITY
    Imagine your property and how far 150 feet will take you; that’s half a football field! Water-filled hose weighs a lot, especially when being drug across the ground while rewinding it. For most users, 150 feet will be more than enough.
    COMMERCIAL-DUTY INLET HOSE
    Made from extreme-duty, weather-resistant rubber, this 5 ft. x 5/8" hose connects the reel to the faucet and features crush-proof brass fittings and spiral synthetic yarn reinforcements.
    CAM-LEVER BRAKE
    When you stop pulling out the hose, this innovative brake keeps the reel from unspooling more hose. The brake’s tension is adjustable and easily turned ON and OFF with the flick of a finger.
    or the
    Freestanding Model
    Price: $139.95
    A durable alternative to plastic “box-style" reels!
    This model is designed for those who prefer not to drill holes for wall mounted reels...or need the frequent portability of wheeled models. It can rest comfortably on the patio, deck, or right next to bushes. A solid, non-tip base is equipped with four no-slip rubber feet for added protection and stability.
    Specs:
    Model.....................1042-GH Max. Temperature...............140°F
    3/4" Capacity.........100 feet * Shipping Weight..................23 lbs.
    Racatac with 3 inch Caster
    Price: $189.00
    The 3” caster model is 1” higher off of the floor and will allow your feet easier and quicker movement when you are in a kneeling /sitting position. This model would be your choice if you need to move rather quickly in a lateral position, using it mostly on rough surfaces, have large feet or long legs, or work mostly kneeling/sitting, such as auto body repair and PDR techs, painters, fabricators, etc.
    Features:
    ADJUSTABLE SEAT – Instead of sitting back on your heels, the fully adjustable seat provides the upper body support, leaving your feet free to control your movement.
    KNEEPADS – Comfortable attached floating-like kneepads allow your knees to rest and move freely. They eliminate direct knee to floor pressure, circulation problems, and will allow you to work in shorts without having to wear kneepads with straps.
    2" or 3" CASTERS – Allow you to roll to move, instead of crawling and bouncing on your knees. Elevates your body and eliminates the normal pressure on toes, ankles and knees. Will allow you to work over dirty, wet, or dusty areas easier and cleaner.
    TOOL TRAY – This feature is really appreciated by all the people that use the Racatac. They love having a place to keep their necessities right there rolling with them.
    Uber Boar's Hair Wash Brush
    Price: $79.95
    7” Wood Block Blonde Boar Brush w/Bumper (very soft)
    7” hand-held or standard handle wash brush with rounded wood-block body, soft blonde boar hair, and rubber bumber for extra safety.
  2. dsms
    dsms DB Forum Supporter
    RACATAC! Love that damn creeper. Honestly one of the smartest purchases I have made yet. That should be a hot seller Phil, not many places carry them:thumb:
  3. detailersdomain
    thanks hopefully they will sell... a few more things to put up...
  4. Denzil
    Awesome Phil! When I can afford it (eventually) I'll be sure to pick one of those up!
  5. detailersdomain
    we have our first shipments coming in to the shop this next week, got to get the place looking good figured I would offer these out to you all.
