just a post to show what i did to my own vehicle in the spring. followed this procedure: wash & dry clay bar megs 3 step (with Pc Da) gold class wax before and after: gonna do it again shortly but use wolf gang 3.0 swirl remover, polish and sealant anxious to see what she looks like after using a quality product, also what kind of wax should i apply over the sealant to make it pop?
What a difference. Try some Blackfire Midnight Sun. Most waxes wiil mute the finish, giving it more of a glow and more depth. BMS has the same polymers as their All Finish Paint Protection. In fact, I'd recommend using those two instead of the Wolfgang Sealant as they are made to work with each other.
Very nice job! Great reflection shot in the garage! I noticed some dusting on the front windshhield. Just a tip but.... if you use an old towel to cover the base of the windshield it will make clean up a lot easier, especially around the vents and wipers.
ok i wanna see some full shots!!! i noticed some chromies along with some MT's also if you want a good entry level wax to make flake pop use XMT 180
