Swissvax cleaner fluid
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by LAV86, Apr 24, 2011.
  1. LAV86
    LAV86 Two Bucket System Washer
    swissvax cleaner fluid regular Will it remove very lite buffer trails/holograms??
    i used the SIP with a uber green pad and PO85rd with a uber blue pad all 5.5'' and the PC..
  2. kyoshiro
    kyoshiro DB Forum Supporter
    dont think that has enough cut
    Probably Swissvax Clean Fluid Professional will do it
  3. Tomas
    Tomas Any Rag Vehicle Washer
    The Swissvax Cleaner Fluid Regular is ment for hand use and is a rinses the paint with chemicals, so it cant remove any scratches, but it does contain fillers so it will/can hide them.
    As kyoshiro said, try the Professional version, i had great success with it on a black Audi A6 from 2000.
    Swissvax CFP on the right sides..
  4. agpatel
    agpatel OD On Detailing
    CF Reg is a non-abrasive cleaner, it will nto remove any swirls/holograms but may hide some of them. You should use CF Med/Strong or Pro if you want correction work and want to use a SV product. But as you have used 85rd/blue ever that is a great finishing combo and should leave your finish pretty darn good...CF will just help with some of the wetness and depth from my experience.
