swissvax cleaner fluid
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by godoman, Sep 13, 2009.
  1. godoman
    godoman Jedi Nuba
    ok guys,
    have figured out swissvax concorso pretty good on my s2000 and know that it is best with two coats after letting the first coat cure for 12 hours. it even looks good on my car with out the car being fully polished to perfection. it is maybe, at best, 60-70 percent and you can not see the scratches at all because of the wax quality and shine.
    here is the thing I am wondering. if I use swissvax cleaner fluid next time and "then" apply the concorso will it make a big difference?
    next, how does one go about applying cleaner fluid? rotary or pc? which pads and at which speeds with each machine.
    any help would be greatly appreciated
    godoman
  2. supercharged
    cleaner fluid will remove any carnauba wax. Will it make paint looking better? Maybe...it depends on paint condition...
  3. svpro
    svpro Birth of a Detailer
    Actually, the Cleaner Fluid will create a clean surface for Concorso to bond.also the cleaner fluid will add oil back into the paint.
  4. godoman
    godoman Jedi Nuba
    can anyone tell me how to apply the cleaner fluid? do you use a PC? if so which pad and at what speed. am looking to try the sv cleaner fluid on my s2000 next time I wax it to remove the wax and then apply a fresh new coat after using the cleaner fluid to remove it, or I could just us an all in one product to do all of that and apply the concorso.
    godoman
  5. advs1
    advs1 DB Forum Supporter
    does it actually contain oils? i would think anything with oil would prevent the bonding of a wax to a non porous surface? the oil would have no where to go and just sit until it evaporated?
