swissvax cleaner fluid vs.LussoRevitalizing Creme
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by LAV86, Oct 18, 2010.
  1. LAV86
    LAV86 Two Bucket System Washer
    Which one is better for very very light hairline scratches ??? Thanks
  2. agpatel
    agpatel OD On Detailing
    Both are non-abbrasive so will not help remove fine scratches but fill them with the oils, temporary adn will wash away after a wash or two. If you want to remove scratches you will need an abrasive polish or if very fine something like BF Gloss Enhancing Polish which is a very very fine abbrasive polish (Little lower or like 85rd)
    On how they work, I have not used Lusso but will say SV CF is a dream to use, very easy on and off and really deepends and crates a rich surface for your wax.
  3. P1et
    As agpatel said, neither will remove scratches or swirls. They are pre-wax cleansers, and will clean the surface before you add a sealant or a wax.
    If you want a very nice polish, have a look at Menzerna PO85RD. It cannot be beat.
  4. Amused
    Amused Any Rag Vehicle Washer
    may want to consider Lime Prime as well...very mild for those faint scratches.
  5. domino
    domino Welcome to Detailing
    yep neither have decent swirl fillers imo, and Lusso didnt look to fill at all in my experience, in fact some swirls re-appeared because it cleaned so well
    if you want a swirl filling paint cleaner try Prima Amigo or Blackfire Gloss Enhancing Polish
    if you want a correcting paint cleaner try Optimum Poli-Seal or Dodo Lime Prime (not Lime Prime Lite)
  6. christian900se
    I really do not like Lusso Revitalizing Creme at all and am now on my 3rd bottle. It worked beautifully the first time I used it and was extremely impressed with it. However, I used it again on my black Saab and it marred the crap out of my perfect paint. I thought I had a contaminant in my foam applicator pad so I threw it away and got a brand new applicator pad. I tried a new panel and it marred the crap out of it too. I poured 1/2 of it out to get to completely fresh Revitalising Creme and with a new applicator, it marred again.
    I got two new bottles and they all did the same so I don't know what the heck happened.
  7. domino
    christian lusso rc isnt a good product regardless
    there are far better options out there, i def would move onto something else
    if you want a good cleaner (only) than doesnt leave anything behind, try the dodo lime prime lite or cg vertua-bond
