hey guys, not sure where to post it but here. i have scratches still left on my car after using Menzerna 106, 85 and final polish (maybe its same thing) with green, white and black lake county pads, on bottle it shows agresivness or something of each polish and i think i need something more agressive to remove swirls, couple days ago i finished all 3 stages of polish and put maguairs nxt was on real quick couse i was freezing my ass off by that time, looks a whole lot better but still scratches, ill try to take pics is there anything in manzerna line up thats more aggressive then what i used? or something else you can recommend? i like maguairs products, maybe their swirl remover couse i seen a lot of levels of polishes, maybe try something from them around 6-8 scale maybe this Ultra Cut Compound - Item Number: ULTRA 32 or this Speed Cut Compound Meguiar's Direct Speed Cut Compound - 32oz ill look on DD once i get home couse its blocked by firewall
You could try SIP or the M95 you have listed. I'm not quite sure what vehicle you'll be using it on but I'd assume it's the vehicle in your avatar. M95 is much noticeably stronger than SIP so you'll definitely want to keep that in mind. Also, M95 is more readily available OTC at just about any paint shop. There's also the M8x series that you could have a look at.
SIP = Menzerna Super Intensive Polish (PO85RD3.02 or PO83Q) M95 = Meguiar's Mirror Glaze #95 Speed-Cut Compound
i think ill try M95 since im sure i can get it at my local body shop store ill stop by there tomorrow
Sure you're aware, but err on the side of caution, because of the soft paint. Your personal preference on appearance dictates your path on how aggressive you want to get on the polish and pad. I have a 93 white Integra, so i tend to go for a clean appearance rather than removing more than is necessary for a perfect finish.
Don't be sorry. Thats what we are here for. The only dumb question is the unasked question. Ask away.....:chillpill:
with white you cants see swirls as much and you have to more worry about dirt then swirls, my parents have white civic and white accord sedan, need to get those done by the way couse it doesnt look good on accord on black when its on sun you can see swirls from far away so need to take care of it or this if i want to stay with Menzerna - Menzerna Power Gloss Compound S34A ????
