Swirls and light scratches - my concept.
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by Ciamach, May 13, 2009.
  1. Ciamach
    Ciamach Any Rag Vehicle Washer
    Hello,
    Patient: well kept white clearcoat, light swirls, some very light scratches
    Gear: rotary, black soft polishing pads, SC Cleaner Fluid Medium, SV Cleaner Fluid, Meg's Paint Cleaner.
    Question: will those above do in removing light scratches and some swirls? I want to avoid serious cutting and multi-step correction, I want to try to manage with what I got - how do you see it?
    I do have some Farecla G3 but i don't intend using it. Shall I go for it and buy something to polish/correct apart from what I have? Do I need some light cutting pads as well?
    I'll be happy to hear your opinion.
    Thanks,
    G.
  2. lifemal
    lifemal Wax on..Wax off
    I would grab a light cutting pad and some Menzerna PO203S Power Finish. It has decent cut for getting out light scratches and swirls and finishes really well. It's my go-to onestep polish :)
  3. Ciamach
    Orange ones are those light cutting, right? Unfortunately I can't get Menz here in PL. SV CF Medium won't do?
  4. lifemal
    Different brands go with different colors for different cuts -- it can get quite confusing sometimes. I've been blessed enough to really only work with Menzerna polishes so I can't really speak for much else.
  5. DaveS4
    DaveS4 Jedi Nuba
    Power Finish w/ the green Uber pad is a killer combo. They key to avoiding micromarring and hologramming/buffer trails is to finish at speed 1 with little to no pressure.
  6. krshultz
    krshultz Nuba Guru
    If we're talking about Lake Country pads, I'd say orange is actually pretty aggressive. It'll finish down "okay," but corrects quite well.
    I see you're in Poland - if you have access to the UK versions of 3M pads (such as the ones sold on polishedbliss.co.uk), Power Finish plus a yellow 3M UK pad is another great combo you could try. For the light swirling you're describing, it's what I'd try first.
  7. Ciamach
    OK, I think I found a good pad, coming back to compound - can you recommend me some 3M product instead of Power Finish?
    I was thinking about Ultrafina:
    Or Extra Fine:
    What would you recommend from those two, or maybe another one? What pad? Light cutting or soft finishing one?
  8. Nica
    I would recommend 3M Extra Fine Compound with a polishing foam pad, that should take care of most of the defects your up against..your luck you can get those polishes locally, I have to order them all the way from the UK :roll:
  9. Ciamach
    Thank you, I was hoping for your feedback. While doing the seach i found that you were using 3M with good results. So, Extra Fine it is then.
  10. Ciamach
    What polishing speed shoud I adjust?
  11. Nica
    If your using 3M Extra Fine Compound, you can use 1500 RPM or between 1200 and 1500 RPM that should do the trick :thumb:
    Which pad are you using?
  12. Ciamach
    I wanted to use black polishing one as you suggested, I have also yellow light cutting one.
  13. Nica
    Well if that's the case, I would go with the 3M Black Polishing pad at about 1500RPM, that should do the trick...oh first spread the polish at lower RPM's and then work your way up, hope this helps :peace:
  14. slanguage
    some good advice offered here.
  15. Ciamach
    Indeed, thank you!
    By the way, it arrived:
  16. Nica
    Nice :thumb:
    You'll be pleased with it, let us know how things work out for you :peace:
  17. scottBT
    scottBT Birth of a Detailer
    if it isnt to bad 3m finnesse it with polishing pad and 3m machine glaze with finishing pad would of probably done the trick but ive heard a lot about the perfect it range so hope all goes well and some pics posted up soon:thumb:
  18. Ciamach
    Well, some defects stayed but it's much better now. I'm not good ad detailed paintwork photos but I hope it shows something:
  19. iddqd
    iddqd Any Rag Vehicle Washer
    Only thing I see is orange peel, so...good job lol
  20. Buddy
    Nice job. It looks very good...:thumb:
