SW Opaque...?
Discussion in 'Detailers Domain' started by MartinD, Dec 13, 2010.
  1. MartinD
    MartinD DB Certified Manufacturer
    Phil-
    Have you used this? Thoughts? This is a matte gray wrap.
    I need it for my Gt3. Thanks
  2. agpatel
    agpatel OD On Detailing
    wow, amazing GT3!
    As for Opaque, know few people in the UK that have used it and say the whole system (Pre-Cleaner and wax) is great. I have used Insignis on my matt black vinyl and talked to Ketil who said it is ok to use it, but will deepen the look a bit. I would say if you want a matte paint/vinyl specific wax then SV is the only one that has anything out as they worked with Lamborghini to create it for the new matte paints they came out with for the Merci.
  3. MartinD
    Exactly what I have heard. You need to bring some of those goodies from your collection up this way ;)
    I do not want to alter the look at all, just protect what is on it. As sad as it sounds, I want it to bead!
    -Martin
  4. agpatel
    Like I have said to anyone in the area, if you want to try anything...just got to come by....nothing is really off limits other then products I only have small samples of.
    I dont get to make it out to Cary/Raleigh area much anymore.
  5. domino
    domino Welcome to Detailing
    if sv opaque was designed for matt paint, wont it react differently on matt vinyl
    afaik matt vinyl does not have the same texture as actual matt paint
  6. agpatel
    It is for both paint and vinyl.
  7. MartinD
    Where in 336 are you? You are more than welcome to PM. Thanks!
  8. kyoshiro
    kyoshiro DB Forum Supporter
    maybe i should vinyl wrap my GLK in MATT BLACK one day, but man your GT3 looks sweet, feel free to ship it over to vancouver and just put the keys in the glovebox, i'll be sure to keep it nice n sparkling clean =p
  9. MartinD
    Thanks for the comments.
    Phil - any advice for matte vinyl?
  10. detailersdomain
    you can use the Opaque, but I can confirm that for you.
    sorry for the delay.
  11. detailersdomain
    Swissvax states:
    The answer would be yes but only if it is a true matt film... most (cheaper) films actually have an imprint in them which gives the appearance of a matt finish but is actually based on a standard film... if you use it on that the wax will build up in the imprint with disastrous effects...
  12. P1et
    Beautiful GT3 sir!
  13. Jayplay
    Jayplay DB Pro Supporter
    as Phil stated make sure its not a textured vinyl
    durability of SW Opague is not that great (1-2 months) so does need topping up frequently
  14. detailersdomain
    thanks for the update.
  15. AutoObsessed
    AutoObsessed Dealers
    The SV Pre-Cleaner Opaque and SV Quick Finish Opaque should be fine for cleaning and quick detailing.
    Another option if the SV products are not suitable is the CG Clear Seal, we supply a local company that does vinyl wraps and it works great on the 3M matt vinyl that they are using. CG Clear Seal is designed for clear bras and vinyl, it had UV protectant and is one of the best QD's that I have used.
  16. agpatel
