1. merlin3008
    merlin3008 Birth of a Detailer
    anyone one here using zep citrus for lsp removal in gilmour foam gun? what settings are you all using? does the gilmour dilute it enough? thanks!
  2. richy
    Sorry I didn't see this earlier, you wouldn't have had to PM me...not that I mind.
  3. merlin3008
    no worries man. i'm just procratinating here at work today. thanks for the input.
  4. Pats300zx
    Well what's the answer Richy?? :)
  5. billyblooshoes
    Yes, I do this all the time. I usually either use 4 or 5 oz of zep in the bottle and fill the rest with water. Or ill mix in a few oz of soap too then fill with water. It works good on the D and E settings.
  6. GDAL
    GDAL Guest
    Another good method is to add an ounce or two in a 5-gallon bucket and mix it with your favorite wash soap.
  7. richy
    Here's the PM response I did:
    Merlin..thanks by the way and I filled the foam cannon container with water and added 2 maybe 3 ounces of Zep Citrus. You could add some to the 2bm too..I just like doing it that way so when I do the 2bm and see no beading I know I'm good. If you do add it to the wash bucket, use an ounce or 2.
  8. bgibs
    bgibs Virgin Detailer
    I used some of this zep citrus in some of my wash shampoo to strip some wax, it sorta worked, i think the wax was just that good, but letting the solution sit, and lightly going over with my mitt seemed to do pretty well.
    I did notice this citrus takes a little while to completely rinse off.. anyone else?
