Street Dreams Detail - Sprint Blue Audi RS4 Corrected & Wolf'd
Discussion in 'Professional Detailer's Studio' started by dsms, Oct 16, 2012.
  1. dsms
    dsms DB Forum Supporter
    Audi RS4 full correction and detail with clear film removal. This car is driven hard and the owner has modified it (rather meticulously) with only the best. Last thing to do was get the paint up to par with a proper detail and correction.
    Wheels and wash process:
    Sonax FE
    Optimum Powerclean
    Citrus Wash
    Iron X
    Nanoskin autoscub on the DA @ speed 1
    Onto film removal, this was done carefully and with the use of a heat gun and plenty of nitrile gloves. Your fingertips and knuckles will be torn up otherwise, there is no way around it. After removing all the film the paint underneath was also Nanoskin'd and then wiped with adhesive remover until everything was gone and smooth before polishing
    Masked trim before polishing, RS4 optioned with the titanium package (no alu trim)
    Healthy paint readings after inspection with both LED and halogen lights. Lots of wash marring and some deep marks, this scared me a bit only because this is a very hard clear coat car and it takes a lot to instill swirls, luckily everything was reversible... with the right pad and polish
    Correction was carried out using both Meguiars and Menzerna. M105 for the initial compounding stage followed by Powerfinish for polishing. All final polishing work was completed with the old reliable and track proven PO85rd on a blue foam pad.
    Under the lights...
    Side skirts as per usual took a beating, you can see the difference in gloss and depth before and after. Sprint blue hides a lot naturally but it can get kicked up a couple notches with correction work
    Original badge needed to be replaced, after removing it and correcting the area the owner decided it looked cleaner badge-less, it just seem to fit better with the cars stance as is
    Badge removed
    Flake back in spades after final polishing
    After polishing the finish was cleaned further with IPA and Eraser before 2 coats of Body Wrap. I won't leave anything to chance when using some of the more boutique sealants and of course paint coatings the finish must be 100% clean before application. Worth the extra effort
    Total time 2.5 days
    Thanks for reading :thumb:
    All the best,
    Dave
  2. dblackn
    dblackn Two Bucket System Washer
    Awesome work! Such a sexy car...
  3. mikenap
    mikenap Jedi Nuba
    Incredible work and incredible car, Dave. The first full car after pic should be made into a wallpaper!
    BTW, I've also got an 849x with the Dynabrade attachment and it is AWESOME! Great choice!:thumb:
  4. boredstudent3
    boredstudent3 Wax on..Wax off
    Does the plate say "RS4LIFE" ?
    Very nice work Dave
    What was the pad and polish combo on the dynabrade?
    It looked like MF pad...MF with M105?
  5. drew935
    drew935 Auto Salon Works
    A favorite color and sweet car. Awesome job Dave!
  6. 911Fanatic
    Stunning finish Dave!
  7. Darkstar752
    Darkstar752 Horizon Detailing
    Great job Dave. That finish looks phenomenal.
  8. v|nsan|ty
    v|nsan|ty Obsessive Detailer
    Great job! Love that color.
  9. vtec92civic
    vtec92civic Nuba Guru
    What a color!? I love blue but that metallic blue looks so sick!
    How do you get those sun shots with the perfect star burst where the sun hits vs having a big blown out sun spot? That car looks fresh and so does your work buddy!
  10. GDAL
    GDAL Super Moderator
    Great work ... that blue is INTENSE!! no other words to describe it!!
  11. kakeuter
    kakeuter DB Forum Supporter
    Car is on point now, nice work Dave.
    -Kody-
  12. adrock2003
    adrock2003 Virgin Detailer
    I've detailed a couple of RS4s, one, the same color as this one and the other was a carbon black metallic that got the works done on it. I can TOTALLY appreciate how hard the paint on these cars is. I had 2.5 days in on the black one as well. Awesome job man. That car is POPPING now!
  13. Chas
    Chas DB Forum Supporter
    Great work dave looks stunning
  14. detailersdomain
  15. Upper Class Detailing
    Great job Dave!
  16. P1et
    That first "after" picture looks out of this world. Wow...
  17. Rocket01
    Rocket01 Birth of a Detailer
    Nice work Dave. The car looks amazing
  18. Socal Brian
    Excellent work Dave.
  19. dsms
    Using an SLR or comparable camera helps although some newer point and shoot cameras can do just as fine a job capturing sun shots. Also helps if the paint is perfectly leveled.
    Really? lol the fender shots are my favorites!
  20. drew935
    With an DSLR, you can add a diffuser to help with the sun glare
    Perfectly worded :applause:
