Stiff/Locking Kwazar Trigger
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by domino, Nov 23, 2010.
  1. domino
    domino Welcome to Detailing
    Hi guys
    recently bought 3 kwazar 1L bottles and have been having problems with the bottle i use with my P21S wheel cleaner
    the trigger is locking and i need to give it a good jab to pull the trigger back, almost like its clicking in place
    anyone experience this? if i dont let the trigger return back to its original position, so only pull and let go at 50% travel it works fine
  2. JPerrydore
    JPerrydore Birth of a Detailer
    I bought these a few months back and have had the same problem with one of them. It's the one I use for my IPA and I use it often. Usually it seems to work fine, but on occasion it does stick like you explaining.
    I put a sprayed it with a little WD-40 and it seems to help some. Still gets stuck on occasion, but not as bad.
  3. trhland
    trhland Nuba Guru
    mine all do that
  4. GDAL
    GDAL Guest
    I'm experiencing the same issue with one of my bottles. It works fine after spraying it a few times.
  5. supercharged
    same issue, but it doesn't bother me much...
  6. AZN_C300
    AZN_C300 Birth of a Detailer
    That's discouraging to hear. I'm on the edge regarding taking the plunge and investing in these bottles, but for the premium price, I'm expecting pretty much flawless trigger action....
  7. kyoshiro
    kyoshiro DB Forum Supporter
    i have 6 of em and dont seem to have problems with water based products (and high dilution ones). maybe u can try pulling off the cap at the end of the "straw" which should let more liquid in instead of getting like air locked (if it may be that)
  8. JPerrydore
    I don't think it's an issue of it being air locked. At least not with mine. I have 3 of them and I use them for my APCs, IPA, & Degreaser. All of which are extremely watery. It almost feels like something inside is getting locked up or snagging on something.
    Either way it only happens to one of my bottles and it's only for a second and doesn't really effect it's performance. Overall I'm extremely happy with these bottles.
  9. vtec92civic
    vtec92civic Nuba Guru
    That indeed is discouraging to hear. As mentioned for those prices i would expect a pretty bullet proof sprayer at least for a while. I know nothing last forever and things eventually break but after only a couple months of usage seems like maybe a factory flaw from the mass production.
  10. Upper Class Detailing
    As JPerrydore said WD-40 should work.
