Hey guys quick questions. Whats best for adhesive removal, particularly those pesky window stickers some gated communities use, also something heavier duty. I have a a car I'm going to do soon that wants me to remove the superman duct tape trim wrap he did on his b5 s4
I do. Was going to go this route but the owner said he attempted to do that and fears the temp would ruin the leather. So now I am removing the door panels to remove the trim and do it all via hand.
If you use a heat gun or hair dryer to warm up the glue it usually will wipe off the majority of the glue. Once you get the majority of the glue off use goo gone or WD40. be sure to let the product work as it does disolve glue. if on a vertical surface I usually spray a paper towel or rag and stick it to the surface and leave for 5 minutes. good luck
