1. SSTG
    SSTG DB Forum Supporter
    Hey guy's where is the best place to buy a steamer?
  2. Obsessive Detail
    I use a Daimer steamer and have been very pleased with it. I got the continuous fill so I can refill on the go without having to wait for the steamer to build up pressure and heat. The Daimer can be used for many other things besides auto detailing as well. It is totally worth the investment.
  3. SSTG
    Thanks.Anyone else?
  4. jetblackZ4
    jetblackZ4 Birth of a Detailer
    I mentioned in another thread our VX 5000 with which we are very happy. This is a commercial unit at a reasonable price. We did alot of research before we bought this one and are very impressed with it. Steve,the owner of the company we bought from provided excellent CS. I would suggest you check out this site. Steam Cleaner - Steam Cleaners - Vapor Cleaner - Commercial Steam Cleaners
    It isn't continuous fill and the site talks about that. We have not had a problem with it running out of water with a variety of tasks and lengthy periods of work. That is of course my $0.02. Others may feel differently.
    Here is a pic of ours in its storage place.
    No matter what unit you get, as long as it's a good one, I'm sure you will be very happy you got a steamer.
    G
  5. SSTG
    I've actually got a call in for him already.His store is in MO where I live. So it's a good unit?Any limitations on it for what we do that you've found?
  6. jetblackZ4
    I really believe it's a good quality unit. Nothing flimzy (sp?) about it in my opinion. I found a number of people on other detailing sites that had them and no one seemed to have anything bad to say that I can recall.
    I'm sure there are probably some limitations in some aspect of its usage but to date I haven't found anything. My wife loves it for the house. I've only used it 4 times I think on interiors so not alot of experience with it there but what I have has been all positive. I'm still finding things to use it for.
    Hope that helps.
    G
  7. SSTG
    Yes it does thank you.
  8. carguy461
    carguy461 Two Bucket System Washer
    how would it work for detailing? carpets, cleaning all interior panel and leather? Either a extractor or vapor steamer? Which would you choose not a bad price either.. need help.:applause2:
  9. togwt
    Hot water extractor - Mytee Lite II 8070.
    No serious detailer should be without a hot water extractor for cleaning carpets, and fabric upholstery; it offers a hot water extractor in a lightweight 3 gallon body. With a weight of only 60 lbs. an incredible 85 inches water gauge that powers out the toughest carpet and upholstery stains. Features like a lift-off vacuum tank, clear view lid, and built-in storage basket make it convenient to use for both professionals and enthusiast detailers.
    Technical Specifications:
    Vac Motor: Single 2-Stage - 5.7''
    Pump: 100 PSI
    Water Lift: 85 inches
    Heater: 1000 Watt
    Housing: 3 Gallon Solution and Recovery Tanks
    Dimensions: 16" x 24" x 37"
    Weight: 60 lbs.
    Tools: 15 ft. vacuum and solution hose and 3 inch stainless steel upholstery tool
    25 ft. power cord
    6 inch non-marking back wheels
    Mytee Lite - Mytee Products, Inc.
  10. razr007
    razr007 Banned
    I use a THERMA-KLEEN VAPOR STEAMER it is the best i have used so far
    I had 5 before this one and one of them is the VX-5000 which is also good machine but runs out of water to fast and does not hold the steam pressure or temp. that long
    I do use it for small jobs but my vapor is the one i use the most they both have great customer service which is a big plus
    But than again depends on how much you want to spend cause the vapor is more costly than the vx so you would have to decide
    Here is who sells the vapor an the vx too there is a video hope this info. helps you if you need to i will answer any other questions i can
    detailing steamer, therma kleen steam machine, Vapor Chief steamer Kleen Car|professional detailing training|equipment
  11. togwt
    My latest toy for Leather cleaning
    Using dry steam vapour: a system that produces a high temperature, low moisture vapour, that contains only 5% to 6% water and is much less dense than air. A steam vapour system is equipped to safely produce thousands of gallons of live dry steam using only about 1.5 quarts of water per hour. It is mess free with temperatures hot enough to kill bacteria and germs, emulsify grease and oil as well as other surface contaminants. These units are best suited for light cleaning (covered leather or fabric upholstery) maintenance, and spot removal
    Apply a cleaner to a sponge, work up a foam and apply to the surface, then pass the steamer just above the top of the area just cleaned and lightly agitate with a micro fibre towel, then wipe dry. Steam vapour helps to emulsify the grime, while the foam encapsulates it. Steam when it cools turns to condensate (water) which helps to re-hydrate the hide
    Steamax Dry Steam Cleaner - easy to use, and light weight, the quick heat steamer converts 2.3 quarts of water into 1,118 gallons of dry steam vapour.
    Is the steamer as good as an extractor for carpets? No, but a vapour steam cleaner will clean carpets if they are not terribly soiled or worn. If they are badly soiled or worn, they should be properly cleaned with a heated extractor system first and then gone over with the vapour stream cleaner to sanitize the carpeting and remove the chemicals left behind. These units are best suited for light cleaning (covered leather or fabric upholstery) maintenance, and spot removal
    Accessories Included
    •Large Rectangular Brush
    •Large Triangular Brush
    •(2) Extension Tubes & Elbow
    •1" Bronze Brushes
    •1" Nylon Brushes
    •1/2" Nylon Brushes
    •Window Squeegee
    •Filler Bottle
    •Terry Cloth Towels
    •Black Nozzle
    •Instruction Manual & User's Guide
    Steamer Specifications:
    •3 Speed Steam Control on handle and canister
    •Indicator Light for refills
    •120 volts (60Hz), 1700 Watts
    •Stainless Steel Boiler: 2.3 quarts
    •Internal Temp: 290.° F, Temp at Tip: 220.° F
    •65 PSI
    •Hose: 8 ft.
    •Size: 19" x 13" x 15"
    •Weight: 20 lbs. Warranty: Two years on boiler, 90 days on all electrical replacement parts.
    TOTL
  12. uncleglenny
    uncleglenny Two Bucket System Washer
    are there any alternatives to the pricey steam machines that still produce dry steam? for personal use they are just to expensive.
  13. Buddy
    I have been using a Steam Buggy. It's no Pro but It will get you out of a jam and do small tasks. 150.00...:shrug:
  14. uncleglenny
