I found the vertuabond marred the paint, how are you applying it/ using it. Car looks great. Whats that color called?
Thanks I applied Vertua hand with a foam applicator. Paint looked better after application, IMO Also checked it with the sungun, no marring. I don't know what the color(s) are called, but I can get the codes for you if you want?
na its ok man. Ill figure it out. With the foam app by hand did you apply the wax over it or remove it. Also with removing it how long did you wait. Did you work the bonding agent in, or just a quick swipe.
Thanks for the comments! I applied Vertua Bond to the whole car, waited about 5-10 minutes, then removed it with a mf towel. Worked the product with light pressure. Tried a foam and a mf applicator, foam seemed to do the job best for me.
last question. Did you apply in straight lines or circles. And did you work it in or just apply? Sorry for all the questions but its greatly appreciated.
Thanks again for the comments! zpectrum: No problem, just ask! Applied the product in circles, worked it in a little bit. Not sure if I did it "the right" way, but it worked well for me
