Spray wax over fresh coat of wax?
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by DetailedbyDylan, Jun 8, 2012.
  1. DetailedbyDylan
    DetailedbyDylan Virgin Detailer
    Hey guys can I use a spray wax on a car after I wipe the fresh wax off?
    Its like a spray detailer but I do not want to mess up the new wax that I just put on!
  2. Chaseme
    Chaseme DB Forum Supporter
    I'm not sure why you would want to use a spray wax after you added a new coat but I suppose it will be okay.
    I would personally do it after it's next wash.
  3. Legacy99
    Legacy99 Wax on..Wax off
    That seems redundant.
  4. DetailedbyDylan
    I was doing it as a second coat of wax, but if you think i should after the next wash Im going to believe you! Im the "Virgin Detailer" here! :buffing:
  5. DetailedbyDylan
    Yes but to me so does doing two coats of wax?
  6. M3ride.
    M3ride. Wax on..Wax off
    Should be fine, depends probably on what you're using. I tend to use Prima Hydro to help buff off wax or sealant.
  7. Legacy99
    Then why do it?
  8. crimsondr
    crimsondr Virgin Detailer
    I just used collinite 845 on my car. Will it be okay to use Optimum spray wax after a wash on top of the 845?
  9. Merlin
    Merlin Virgin Detailer
    It depends...what QD is it?
  10. LukeF
    LukeF Any Rag Vehicle Washer
    That would work fine. I personally like the look and feel of 845 untopped. I use OID as a drying aid, but rarely OCW. However, I have done it with no adverse side effects. I always like to give Collinite waxes enough time to cure though, if it is not completely removed it could leave pseudo-holograms which can be a paint to remove. Then after the first wash topping with OCW would work fine.
  11. Merlin
    Some QD's are wax, some are polymers and some have no "protection" at all.. Although both wax and polymer QD's "will work" it is suggested to use a wax QD with wax and a Polymer QD with a sealant. Megs Ultimate QD, BF Polymer spray are a couple of polymer examples. Optimum spray wax should be fine over Coli 845.
  12. crimsondr
    Thanks. I actually use ONR at QD strength for my QD and for drying.
