Spary Bottles at Lowes
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by piginapoke, Jan 24, 2012.
  1. piginapoke
    piginapoke Obsessive Detailer
  2. RefPerfection
    RefPerfection Birth of a Detailer
    We currently have 4 in use at my shop right now. They work well, nice adjustable nozzle from fine atomization to stream, as well as a locking mechanism for constant flow without holding the "trigger", if you will. Just be careful of over pressurizing, as we've had 2 seals fail in the past, likely due to that reason. I'd consider them a good bang for the buck.
  3. Kilo6_one
    I have them, i like them.....no major issues, it is a good alternative to the Venus Pro bottles.
  4. hamza7
    hamza7 Welcome to Detailing
    I don`t know if there the same ones over here, but I`ve broken 2 because I`m ruff with my detailing gear. I drop stuff all the time so the pump broke partially it still works a bit but it should give you great use if you use it carefully.
  5. nyrep1
    nyrep1 Obsessive Detailer
    i bought 4 broke 2 of them but for 7 bucks i plan to buy them again
