SONAX High Speed Wax
Discussion in 'Detailers Domain' started by agpatel, Jun 9, 2010.
  1. agpatel
    agpatel OD On Detailing
    Anyone use this product, how is it compared to Opt Car Wax. Had a sample of Opt Car Wax and looking to get something to use after car washes to keep the wax going and was going to get OCW then remembered Sonax had something out as well. Just like to hear some opinions on HSW.
  2. 911Fanatic
    I have it and have been using it lately. Super easy to use. The look is definitely carnauba. The only issue I have with it is that dust seems to stick to it. My shop is in an area that is quite dusty and even right after applying the Speed wax, the dust doesn't blow off when I drive,
  3. agpatel
    How would you compare it to my favorite SC SW20?
  4. detailersdomain
    solid product. have not used SC
  5. 911Fanatic
    SW20 leaves a shinier, slicker finish. Similar to DG Aquawax whereas SW leaves a deeper, carnauba look.
  6. detailjohn
    detailjohn Detailers Advertising Scheme
    I love the High Speed Wax, probably my favorite spray wax. You can tell it actually leaves some protection behind, and a nice shine.
  7. agpatel
    Have you used OCW? If so how would you compare it?
  8. 911Fanatic
    OCW falls between the two in terms of looks Ank. SW20 is the shiniest followed by OCW and then Speed Wax. Speed Wax is the easiest to apply of the three although none of them are hard to use.
  9. detailjohn
    The products are comperable, but Sonax has probably one of the best misting sprayers in the industry, and the product is a little thicker than the OCW. Both will do a good job for you.
    John
  10. 911Fanatic
    I agree. Sonaxs sprayers are awesome. Very smooth, fine, even mist.
  11. agpatel
    Too bad I cant reuse the Sonax wheel cleaner bottle for something else as it smells like crap!
  12. Fox
    Fox Any Rag Vehicle Washer
    I just tried this speed wax. It was actually surprisingly difficult to buff off, but I believe this could be my water filter going out, leaving some hard water film on the car. The beading on this was absolutely amazing.
  13. porta
    porta Jedi Nuba
    Nice to see that a OTC product from Europe is rated highly.
  14. 911Fanatic
    I would urge you to try again after changing the filters. I found it to be extremely easy to use. I got around my Passat wagon in under 10 minutes. :)
