Should we get a Metabo PE12-175 deal going?
Discussion in 'Detailers Domain' started by detailersdomain, Apr 21, 2009.
  1. detailersdomain
    Let me know.
    $259.00 shipped with in the USA (less Alaska and Hawaii) via FEDEX Ground
    let's get a list going.
    1. edwingbong
    2.
    3.
    4.
    5.
  2. How much we talking?
  3. detailersdomain
  4. slanguage
    HMMM. Like I need another machine. How much does it weigh compared to the makita?
  5. d00t
    d00t Welcome to Detailing
    How about a Flex Rotary? :tiptoe:
  6. detailersdomain
  7. detailersdomain
    You mean the Flex 3403?
  8. d00t
    Yep :thumb:
  9. detailersdomain
    that's already dirt cheap...
  10. edwinbong
    edwinbong DB Forum Supporter
    lets get the metabo ball rolling!
  11. DaveS4
    DaveS4 Jedi Nuba
    Hmm I *might* hop on this depending on timing...
  12. detailersdomain
    let me know I need 5 to make this one happen.
  13. detailersdomain
    also did you want a 5 .5 inch pad kit plus the 3m backing plate as well.
  14. Petrucci_M3
    Petrucci_M3 Jedi Nuba
    How well does this compare to a Flex 3403? I've been using one for the last 6 months and I'm looking for a backup or main work horse to switch back and forth with.
  15. detailersdomain
    I believe both are great!
  16. MadOzodi
    MadOzodi Nuba Guru
    The Metabo also has a slower starting speed than the 3403. People love the fact that you can fit the 3403 in tight spaces after you remove the bail handle. What you don't see mentioned is the fact that you can fit the Metabo in even tighter spaces once you remove the ergonomic hand cap, due to its smaller profile.
  17. crew219
    crew219 Birth of a Detailer
    The metabo is also much quieter than the Flex. Quite happy that I don't need to wear earplugs while using it.
    Dave
  18. Smith2287
    This is a great machine that I got from Phil last year. I use it in tight spots rather than my makita, I just got the gloss it small BP so I can't wait to try it with my small 3m pads I got from carlos!!!!
  19. edwinbong
    1. edwinbong
