ScheerSpeed: Full detail on a Range Rover HSE
Discussion in 'Show and Shine' started by scheerspeed, Aug 16, 2008.
  1. scheerspeed
    This car had never been detailed. it was about a year old, it has been taken to the car wash for a wax every so often, but this time the owner wanted PERFECTION. and thats just what he got. this car needed wetsanding in some places, and a full 3-step polish. as far as he paint goes, it was in pretty bad shape...
    Exterior
    -Wash
    -P21s TAW Pre-soak
    -CG CWG
    -CG Waterspot Remover
    -White/yellow shMITT
    -Engine
    -Meguiar's Super Degreaser
    -Meguiar's Hyper Dressing
    -Wheels
    -CG Citrus wheel cleaner
    -Meguiar's Wheel brightener
    -CG CWG
    -EZ detail Brush
    -Black shMITT
    -Amazing Roll-off (tires)
    -Swissvax Autobahn
    -Wheel Wells
    -Simple Green
    -black shMITT
    -Clay
    -CG Gray clay
    -CG Synthetic QD for lube
    -Correction
    -2000 grit (3M wet-or-dry) sanding paper
    -Menzerna Powergloss
    -Menzerna SIP
    -Menzerna PO85RD
    -LC Foamed Wool
    -LC yellow compounding pad
    -LC orange pad
    -LC white pad
    -Sonus SFX white pad
    -Sonus SFX blue finishing pad
    -Makita 9227C
    -3M yellow backing plate
    -Edge foam pad cleaner
    -ISA wipedown
    -LSP
    -Collinite 915
    -FK1# 425
    Interior
    -CG leather Cleaner
    -CG lightning fast
    -1Z cockpit Premium
    -1Z Gummi Pflege
    -Zaino Z10
    -303 protectant
    -Stoner's Invisible Glass
    Well to start, i arrived at fire station #4 (again!) at 7:00AM. i took a quick look at the car and i told the owner that it didn't look like it was in too bad of shape, except for some big scratches, which i was told to remove. first off i decided it would be better to degrease the engine before moving on the the paint, so that i would not dirty the paint.
    Letting Meguiar's Super Degreaser soak in. then i gave the heavily soiled areas a scrub, then rinsed off.
    now it's time for the wash. using the two-bucket method with grit guards. i first washed the wheels, then the car. after the wash i clayed the entire car using CG's Gray clay since this car had never been clayed in the past.
    after the wash and clay
    CG's Citrus wah n gloss sure does leave a nice looking shine! but don't be fooled! now onto the halogen lights!
    well that paint was in pretty bad shape... so i decided to try a test panel using SIP on a orange pad.
    it got most of the defects out of that panel. so i decided to go on with that combination. i moved onto the hood.
    now that didn't seem to do much as far as taking care of the RIDS... so i decided to bump it up a notch to Menzerna Power Gloss on a Purple Foamed Wool Pad.
    still left some RIDS...
    after 1 pass with Power Gloss
    after 2 passes
    so at this point i had to resort to sanding using 2000 grit paper in order to get rid of the RIDS
    and after powergloss of the same panel
    the center of the hood
    1 pass wasnt enough....
    did anyone say powergloss isn't dusty?
    more before and after shots
    these scratches were caused by a luggage cart from a hotel running into the car. they had to be sanded out. some small parts of it had unfortunately gone too deep...
    after powergloss
    after SIP
    and that was the end of day 1. i left at 11:00PM.
    the next morning i arrived back at the station and got started again at around 8:30AM. i re-washed the car because it sat outside at night and got rained on. then i went back to polish the whole car (including the roof) over with SIP on the white sonus SFX pad because my CCS pads were acting up for some reason. i think it had to do with the "sticky clear coat" issue.
    SIP finished down pretty well on the hood with the sonus SFX white polishing pad.
    now for the final result of 2 hard days of polishing. these shots are after polishing with PO85RD on the blue sonus pad and given a ISA wipedown
    50/50 of Black WOW
    after LSP
    that marked the end of day 2. i have another job at a restaurant that i had to be there at 7:00PM, so i left the station around 6.
    Day 3 was at the owner's house. this was just to do the interior. i started out with cleaning the carpets with CG's Lightning fast stain remover.
    extracted water...
    the doors, steering wheel and seats were full of body grease and makeup (it's a woman who drives the car)
    so i gave the leather a good cleaning with CG's leather cleaner, the plastic and LCD screens with 1Z cockpit, and then applied 303 protectant to the dashboard, and Zaino Z10 to the leather seats. then i applied 1Z gummi pflege to the weather seals. then cleaned the glass using stoner's Invisible Glass
    and to finish it off i cleaned off the door jams with FK1 # 425
    well i hope you all enjoyed looking at that! it took a lot of hard work to get that shine out of the paint!
    thanks for looking!!!
  2. Brian N
    Brian N Jedi Nuba
    Wow amazing turn around, I am in awe. And wow does Powergloss dust it looks like a bottle of baby powder exploded in the garage or something.
    One question what kind of light set up is that? Like how many watts are you running? Thanks.
  3. bryansbestwax
    Nice work
  4. scheerspeed
    thanks! it's 1000w husky lights
  5. bigpoppa
    bigpoppa Jedi Nuba
    That picture with the Powergloss dust looks like Tony Montana's desk in the final scene of Scarface. :gasp:
    Nice work
  6. scheerspeed
    haha no joke! it really does!
  7. Nica
    Well done :applause: vehicle looks great. These SUV's are deceiving they don't look that big but when you start polishing it, it just never ends lol.
    Job well done :worship2:
  8. detaildoc
    detaildoc Guest
    Wow! That looks awesome. Great job! How do you like that FK 425?
  9. FuelTuner
    FuelTuner Birth of a Detailer
    holy crap! those pics bring back some bad memories of black Rovers!! Awesome job!! Those things suck to polish!!
  10. scheerspeed
    thanks guys!
    doc- it's my favorite QD!
  11. 911Fanatic
    Awesome turnaround! Hard to believe people can treat their cars like that.
  12. scheerspeed
  13. yukonon22
    yukonon22 Wax on..Wax off
    Awesome work.
