ScheerSpeed Detailed: 1998 Jaguar Xj8
Discussion in 'Show and Shine' started by scheerspeed, Aug 23, 2010.
  1. scheerspeed
    The only way to describe this job was that it was the most labor-intensive work i have ever done to a car. the paint was in horrible condition because it sits outside every day and hadnt seen any TLC in years. When i had first given the owner an estimate i warned him that the paint would probably not come out 100% perfect because of a lot of cracks from it being so dried out. however the car had a sentimental value to the owner so repainting it was not an option. i had to wetsand the entire car by hand using 2000 and 3000 grit paper and then properly finish the paint to a brilliant shine. I spent 7 days working on this car.
    PRODUCTS USED:
    Wash
    -Chemical Guys Citrus Wash
    -P21s TAW
    Wheels
    -P21s Gel
    -Sonax wheel cleaner
    -Ace Powerstick
    -EZ Detail Brush
    -SV brushes
    Clay
    -Special yellow poly clay
    -ONR lube
    Polishing
    -Exterior paint
    -Meguiar's 2000 grit and 3000 grit wet-sanding paper
    -Meguiars M105 with a black wool pad
    -Menzerna Power Finish with a Green über pad
    -Makita 9227C
    -3M Yellow Foam Backing Plate
    -Brinkmann Dual Xenon
    -Menzerna Top Inspection
    -DD über MF towels
    -Racatac
    LSP
    -Paint
    -Zymol HD Cleanse
    -Zymol Royale applied by hand (using the palms of my hand, not an applicator)
    -Wheels
    -Menzerna Power Finish with a Mother's Powerball for Paint
    -Poorboy's wheel sealant
    Glass
    -Adam's Glass Cleaner
    Interior
    -1Z Cockpit
    -Chemical Guy's Leather cleaner
    -Leather Masters Vital / Protection cream
    -1Z Gummi Pflege
    metal
    -Optimum Metal Polish
    -#0000 steel wool
    Here's how she looked before. note how there is absolutely NO REFLECTION on the hood, trunk, and roof.
    On the inside, the leather was extremely dry, and the carpets were filthy with stains and dirt.
    the plastic around the door handles was drying out. later we applied Black Wow to bring them back to life!
    the engine was extremely dirty...
    we also removed the wheels to do a thurough cleaning inside the wheels and wheel wells.
    here's how the wheels came out after soaking in Sonax wheel cleaner foe about 15 minutes. After, we proceeded to clay the wheels to remove the rest of the dust build up.
    some tape residue that had dried on for probably a few years. i tried 3M adhesive remover and 1Z Industrial Cleaner, however neither made even the slightest difference. the only way to take this off was going to be polishing it away.
    Here's the paint all clean and ready to be sanded.
    here's a 50/50 that i did on the hood
    next, i had to do some touch up work. i had to get some paint mixed at a local bodyshop because the color had been discontinued from jaguar. i used two different brushes to apply.
    here's the trunk after sanding
    and the mirror after polishing
    the tailpipes were very nasty
    applying 1Z gummi Pflege to soften the door seals
    Finished!!!
    Thanks For Looking,
    Dom
  2. Rcrew
    Rcrew Wax on..Wax off
    HUGE turnaround. You should feel proud about that one! Hope you charged appropriately for all the sweat you put into it though.:thumb:
  3. cnut
    cnut Guest
    Tremendous difference!!! How long did it take you? Great, great work indeed!
  4. kei169
    kei169 Wax on..Wax off
    good one!!!
  5. P1et
    FOOK ME that's fantastic, good to see you post up again!
  6. dsms
    dsms DB Forum Supporter
    That was BAD as it gets! Nice work
  7. slanguage
    Very nice work Dom. About how many man hours did you put into it?
  8. Max405
    Max405 DB Forum Supporter
    Thats INCREDIBLE!
    A job that can only be done by a professional.
    Outstanding!
    Joe D.
  9. 911Fanatic
    Fantastic job Dom. That IS worse than any of the BMWs you have done and thats saying something. Unbelievable turnaround to say the least.
  10. scheerspeed
    hey guys thanks for the comments. im not sure how many hours it took me, but i worked on it for 7 days!
  11. GDAL
    GDAL Guest
    Incredible transformation on a color that hides imperfections. Well done!!
  12. vtec92civic
    vtec92civic Nuba Guru
    man. i was just checking out your website the other day wondering WTF happened to you LoL and then BAM! You post up.
    Hows business been man? The Jag came out looking fantastic. I never knew you could sand cracked paint. It's to bad the owner waited so long . . . . . i would have thought that if the vehicle had sentimental value he wouldn't have let it get that way.
    Anyways enough about the Jag . . . . your Black M3 Sedan is off the walls sick. If it's one car i want to own it's that very car. Nice work.
    E90 M3 Correct?
  13. supercharged
    amazing work on a cat!!!:mounty:
  14. michakaveli
    Great job! :thumb:
  15. detailersdomain
  16. scheerspeed
    lol sorry i havent been posting threads up lately, business was kind of slow over the summer... and thanks ,and yes its a e90 m3 :mounty:
  17. Old School1980
    Old School1980 Any Rag Vehicle Washer
    WOWOWOWOW:worship2:
  18. kenzo14
    kenzo14 Virgin Detailer
    That was epic. I'm sure it wasn't an easy task at all. But after seeing it detailed, cleansed and all that.. It came out like a jaguar worth treasuring.. The exterior jaguar parts looked like new. Great job on that!
  19. wise 85
    wise 85 Virgin Detailer
    That was one messed up big cat, a truly beautiful turnaround:applause::applause:
  20. swest0223
    swest0223 Any Rag Vehicle Washer
    WOW! What a turnaround! Great job! Did you have to use a hot water extractor on the interior?
