Saphire black 335i recieves some TLC...
Discussion in 'Show and Shine' started by Carn, Aug 19, 2009.
  1. Carn
    Carn Welcome to Detailing
    Another weekend meant yet another detail, this time around it was the turn of a saphire black BMW 335i. Vincent, the owner, contacted me some time ago whilst Grant was still in ICU and wanted his pride and joy to receive some TLC as she was looking a little tired.
    Either the previous owner, or the dealership must have had the car polished at some stage as it was covered in holograms. Being black and a BMW (which usually have some pretty hard clear coat in my experience) I figured I would be in for a rough ride...Let's see how it all panned out!
    After arriving and getting setup, this is what I was greeted with...
    Judging from the exhausts and wheels it was clear that this baby had spent some time away from the car wash. Having not even washed all the dust and previous 'paint treatments' (if any were remaining) off, the holograms and swirls were quite evident...
    Anyways, as usual I started with the wheels seen here soaking in a heft dose of Sonax Extreme rim cleaner while I set about filling the buckets and getting all the brushes, etc ready.
    No pics from the wheels or wash stage I'm afraid. As you can see there was no shade outside and I wanted to get the car washed and rinsed as quickly as possible to avoid water spotting. After the wheels and arches were cleaned I set about rinsing the car thoroughly before giving it a wash down with 10:1 APC. A final heavy rinse completed the wash stage before moving into the garage to dry the car.
    Once dry I pulled her back outside to get a closer look at the now clean paintwork. Outside in the nearly mid day sunlight I actually struggled to capture alot of the defects, regardless here are some of the ones that came out alright...
    In the interests of preserving my retina's I moved back inside and proceeded to inspect the paint under the halogens, as well as with the new LED Lenser swirl & hologram spotting LED torch I have been fiddling with. This proved to be much better on the eyes and also came out far better in the photo's.
    Usually I have found holograms particularly difficult to spot under halogen lights but this baby bared it all!
    Some swirling, RIDS and hologramming from other area's around the car...
    Tailights lightly swirled
    With the halogen inspection out of the way I whipped out the LED torch I recently got to see how it would fare. Needless to say it didn't disappoint and I was impressed with the defects it highlighted.
    Holograms, swirling and marring all present
    Apart from impressive collection of hologramming, the car was covered in minor swirls with relatively few deeper RIDS. When I see a car like this that has only minor swirls, I always have 2 thoughts: Either the owner has washed the car with care, or the paint is fairly hard having put up a decent fight against the swirls. Only one way to find out...
    With the inspection completed the car was taped up before setting about finding a suitable pad and polish combo to tackle the paint defects.
    As some of you may recall from the black Mk V GTI I detailed recently, I hinted at a new polish I had been playing with. This detail provided me with the perfect opportunity to further test these products on an unforgiving colour, coupled with paint that is more often than not on the harder side of the spectrum.
    Righty then, first up the S30 finishing polish on my trusty 3M polishing pad. After working the polish with the usual zenith type technique (spread at 600, bumped up to 900 and then 1500-1800rpm's before finishing at around 900 again) the results gave me hope. Whilst the swirling was still present, the hologramming had been significantly reduced. With that out of the way and the results not up to par correction wise I moved on to the regular S22 micro polish. Better results, similar to those of the finishing polish, but still some minor swirling remained.
    At this point I was begining to think this would become a 2 stage job as the next product in the line-up, S17, borders the aggressive polish/mild compound boundaries and I feared that whilst it would almost certainly deliver the correction I aimed for, it would leave it's own mild hologramming that would need to be further refined. With the above in mind along combined with the fact that I really wanted to spend a Sunday relaxing as opposed to detailing, I decided to try a few things with the product to see if it was possible to finish down LSP ready without the need for further refinement.
    After playing with the working time, speed, pressure and pad movement, I was thrilled to find that this product can finish down with a crisp clean gloss that closely rivals the likes of Menz 106FA, whilst still delivering correction levels slightly superior to that of SIP :cool:
    Below are some pics from the test sections on the bonnet
    Swirling practically completely knocked out
    No signs of holograms and RIDS
    And some crisp flake coming through the clear coat
    Confident that the product could finish down LSP ready and armed with my new LED torch that easily highlighted even the feintist of defects, I set about correcting section for section whilst monitoring the results with both the halogens and LED torch. Working in this manner taught me a hell of a lot about getting the best out of this product as variations of the basic techniques yielded different results that could be easily and immediately observed.
    Enough blabbing on for now and lets get back to the action...
    Remember the passenger door?
    Thats better
    Close-up highlighting the metallic flake
    The knackered doors...
    Untaped 50/50
    Thats more like it!
    More hammered plastic B-Pillars
    After polishing there was some feint hologramming left by the product which required a second hit with the finishing polish to remove. This leads me to believe that the S17 may not finish down all that well on softer surfaces, but in it's defence it is formulated for ceramic paint finishes and not plastics.
    Nearly good as new after the 1st hit. No pics after the finishing polish though, I forgot!
    One of my favourite parts on this car turned out the be the rear fenders for some or other reason...I couldn't stop starring at them :headbang:
    With the passenger side completed I pulled out into the sun to make one final check and to ensure that the halogens and LED torch weren't deceiving me. Some pics from out in the sun...
    Convinced for certain that my eye's weren't lying to me I headed back on inside to complete the correction phase. It was beginning to seem as if I would have sunday off after all :headbang:
    A few random reflection shots I decided to snap before I got busy again and whilst there was still daylight.
    Moving on to the rear of the car we have:
    Swirled and hologrammed boot lid
    Fully corrected
    Rear bumper before and afters (different sides but you get the idea)
    And finally, drivers side rear fender before and afters
    With the correction phase completed around 7-8pm it was back outside for a final wash before being dried and brought back inside for the LSP and finishing touches.
    LSP of choice was Pete's 53 which always goes on and off without issues, is durable and adds a little something to the paint in terms of depth and wetness. Tires got Meg's Endurance Gel and the trim was treated to 303 Aerospace.
    With it being just after 10pm there was no chance of any decent after pics so I snapped a few reflection shots inside the garage and hoped for the best considering I didn't bring the tripod along...
    With everything done and dusted and having spent a wonderfull warm day out detailing with a most gracious and enthusiastic host, I headed down to McD's for some graze before heading on home. Total work time was 13 hours or so which was a welcome change from the regular 18-20+ hour stint's of late :applause2:
    Below are some pics the client snapped early on Sunday morning whilst I was still snoring. Big thank you goes out to him for forwarding these on to me, they are simply stunning :cool:
    And finally
    As always, thanks for looking :thumb:
  2. skurzhun
    skurzhun Birth of a Detailer
    Nice job.
    More pics of girl on bike.:D
  3. THE ONE
    THE ONE Birth of a Detailer
    great job :applause:
    ill be doing an 07 3251 and its in pretty bad shape. hope i can get it close to this. :mounty:
  4. Buddy
    Great effort. It looks beautiful...:thumb:
  5. dsms
    dsms DB Forum Supporter
    Great work and writeup! The 50/50s tell the story!
  6. Chas
    Chas DB Forum Supporter
    nice job, I love the Saphire black and you really brought out its beauty
  7. supercharged
    Gordeous!!! I love this shot -
  8. Solidsnake
    Solidsnake Jedi Nuba
    That car got a bossy look! Nice turn around, man.
  9. bentley147
    bentley147 Jedi Nuba
    very beautiful !!! black paint
  10. slanguage
    This shot is Money$$$
    Nice work Carn!
  11. corrswitch
    corrswitch Jedi Nuba
    Nice job. Loved the pictures, especially the last picture which showed how detailed the job was.
  12. Ch40t1c
    Ch40t1c Obsessive Detailer
    Excellent job, that fin is looking fantastic.
  13. JLs Detailing
    Phenomenal job as always David! Love seeing your work and this was no exception. When I get on DB and see a Carn detail on the front page its the first thread I open. I have to agree with Slanguage on that shot being the best shot of the lot!
  14. sal329
    sal329 Nuba Guru
    Great job the car looks amazing, nice clean and crisp in the pics
  15. Berscht
    Berscht Jedi Nuba
    Wow, that quarter panel is mezmerizing.
