Rupes Mini 5" BP???
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by Hum-Benz, Jun 13, 2014.
  1. Hum-Benz
    Hum-Benz Wax on..Wax off
    Since the duetto and the Mini share the same body, motor and specs.....Can anyone confirm if a 5" backing plate will work on this model? Or if someone has either the 15/Duetto and the Mini try it for me. Many thanks.
  2. detailersdomain
    I was thinking the same, but unfortunately they do not have the same heads. ; (
  3. Hum-Benz
    There goes that idea.
  4. Hum-Benz
    Have you actually tried it already?
  5. StreetShotz
    StreetShotz New Member
    I know the 5" will fit the 15 and 21 with no problems.
    Would be awesome if it fit other machines.....but them Rupes would not make money producing other machines :p
    Going to have to order 2 more machines to fill the void I currently have.
  6. The Driver
    The Driver Birth of a Detailer
    They do fit, they will most knock the balance off. I fitted them just to see if they could...
