Rotary Buffers and why......
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by triax, Jul 23, 2009.
  1. triax
    triax Virgin Detailer
    Metabo PE12-175 - 6.4 amp - 5#'s - 700-2200 rpm
    Makita 9227-CX3 - 10 amp - 6.6#'s - 600-3000 rpm
    Flex L33403 VRG - 11 amp - 4.85#'s - 1100-3700 rpm
    Vote it up and why!!!!!! - :headbang:
  2. Darkstar752
    Darkstar752 Horizon Detailing
    Make a poll.
    And Makita because it seems to be the best overall, it's what I use.
  3. Spyral
    Spyral DB Forum Supporter
    FLEX, because I love mine.
  4. DanPonjican
    DanPonjican Birth of a Detailer
    Makita. Smooth, quiet and most reliable.
  5. krshultz
    krshultz Nuba Guru
    You forgot the Edge rotary.
    Me? I'm a Makita guy. It seems just about perfect - one of those tools that makes me smile every time I use it.
  6. SSTG
    SSTG DB Forum Supporter
    Makita's my fav.
  7. D&D Auto Detailing
    Dynabrade because its better than all of those.
  8. odgaard
    odgaard Birth of a Detailer
    Makita but wish it weighed less
  9. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    If that isn't the truth.
  10. Buddy
    Makita is my choice because you can run the rpm's down to apply sealants and wax or crank it up to the work horse mode. It's just an all around great machine with great reliability and I really like the color too...:thumb:
  11. Jorgen
    Jorgen Virgin Detailer
    i have a milwaukee machine and its a pain in the ass to work with.
    Don't know if i'm doing anythin wrong but it starts cut an wobble
    when i use it with a buff. :shead: But with wool its great a bit heavy
    but it feels like a reliable machine a well built machine.
  12. rwisejr
    rwisejr DB Forum Supporter
    Makita as its is the best all around unit .For price,durability,weight and availability
  13. SpecC
    SpecC Wax on..Wax off
    the dynabrade is actually really reasonably priced, but used makitas are too cheap to pass on for me. i had a hitachi which was very similar
  14. Rennes
    Rennes Jedi Nuba
    QFT! :worship2:
  15. michakaveli
    I'm very happy with my Makita purchase. Makes me smile every time I use it. :mounty:
  16. Dream Machines
    Dream Machines Jedi Nuba
    Metabo is what I am getting to back up my Makita 9227
    Metabo's can overheat and replacing brushes and servicing may be needed more often
    Flex - 1100 is too fast to start with IMHO. I start at 600 but sometimes 300 with the makita using the trigger really lightly
  17. detaildoc
    detaildoc Guest
    Makita FTMFW!
  18. SpecC
    at 1100 from my experience, it's hard to pick up polish that you laid down on the car too. I like the Makita because it starts at low speed, so as you pick up the polish, it doesn't spit everywhere and make a mess.
  19. DJ_JonnyV
    DJ_JonnyV DB Forum Supporter
    I just did a black GMC Sierra extended cab 1 step polish the last 2 days with my Flex 3403, and it was a lifesaver. I've been transitioning from a Flex 3401 to the 3403, and my rear would've been handed me if it weren't for the 3403. I like it because it's nice and light and very maneuverable. It does get pretty hot. The high RPMs used to scare me to be honest with you. I get going a little different than most probably in terms of picking up polish. After the pad is primed, I usually use about 3 pea sizeed dots (on a 5.5" pad) and dot it over the section I'm doing, then I'll feather the trigger a little to get it going, and lock int at 1100. After using it for a little while, you just get used to it. I guess the only downside I see with it is that it does run hot, if you get your hand/fingers on the motor housing, it's like touching a pizza pan coming out of the oven.
  20. lasthope05
    lasthope05 Jedi Nuba
    Im guessing you havent used a Milwaukee or dewalt yet. They are both heavier.
    Anyways, I have dewalt and after using my friends makita im definitely going to have to make a switch. My main reason is the lower working speed that would really help to refine/jewel/burnish a finish. The soft starting feature is a plus along with the weight to me.
    They are all variable speed trigger controlled anyways so it doesnt matter what rpm's their starting speed is. You should be able to pick up polish at any speed as long as you know the technique.
    Anybody wanna trade their makita for my dewalt? :D
