Review: Metal polishes
Discussion in 'Car Detailing Product Discussion' started by matrix_808, Nov 11, 2008.
  1. matrix_808
    matrix_808 DB Supporter
    Had the time today to test out a few metal polishes on an old exhaust. Up for testing was Autosol, P21s Multi-surface Finish Restorer, and P21s Polishing Soap.
    Picture of the exhaust for testing
    Autosol
    P21s Polishing Soap
    Finished
    Now on the really tuff stuff, however only tested the polishing soap and Autosol. Autosol on the left and polishing soap on the right.
    Overall to me it seems that the polishing soap did a better job in cleaning in both cases. The finish restorer is pretty thick and not very easy to work with. Autosol is a little thinner in consistency and at the same time very easy to use and still does a pretty good job in cleaning. I would personally stick with Autosol or the polishing soap.
  2. slanguage
    The polishing soap looks like the winner here.
    Thanks for the review and pics!!
  3. Denzil
    Thanks for the review Brent!
    Hmm, looks like the polishing soap did a noticeably better job than Autosol. How does it compare in price?
  4. Kron
    Kron Two Bucket System Washer
    Theres definately more clarity with the polishing soap, How hard was the included applicator sponge though?
  5. Buddy
    AGREE- The polishing soap looks good to me too...:thumb:
  6. eyezack87
    eyezack87 Guest
    Sweet review Brent! I've been looking for a metal polish too :)
  7. 911Fanatic
    I've been using the polishing soap for about two years now and I'm always impressed with it. If you are cleaning a car with chrome bumpers, after you wash them, go over them with the Polishing Soap and then rinse. You'll crap your pants at the shine!! The applicator pad is soft so watch it on things like exhaust hangers. Excellent product.
  8. Hum-Benz
    Hum-Benz Wax on..Wax off
    Matrix--- I actually have both P21S versions and I tend to use the soap for the heavier grime such as exhausts and my kitchen sink....lol. For chrome handles, mirrors etc I will use the Finish restorer since it's not as messy and you can work the smaller areas better. Keep in mind that the sponge they give you with the soap has been known to cause scratching on chrome surfaces.
  9. matrix_808
    Price wise, cheapest i found Autosol was on ebay for like $10-$15 shipped for the 3.33 oz tube. The polishing soap is only $10.99 at Autogeek. Ya i was pretty impressed with the polishing soap actually. Instructions say to just dampen the sponge and start scrubbing pretty much. All this time i have been using autosol and loved the results, but think i may start using the polishing soap more. It may be a bit difficult to use the sponge in tight areas like in the exhaust piping, I wonder how well it would still clean with a damp towel instead.
    As for the included sponge, its pretty firm, but i think its pretty safe as some (including me) have used 0000 steel wool
    Oh thought i would add, the polishing soap cleaned VERY easily out of the sponge pad. Just blasted it with the hose and squeezed a couple times and it was clean. I used Autosol on the pipe with the same sponge pad and its a bit more greasy and I needed to take some Dawn to it to clean it out.
  10. zspectrum
    zspectrum Jedi Nuba
    Those results seem great. Ive always wanted to use the p21s soap and I def will now. I agree with the finish restorer being hard to work with.
  11. Nica
    Good review :applause2:
    I've used the P21S Polishing Soap several times but I prefer Autosol, but it is true P21S Polishing Soap will leave a greater finish I find it takes a long time against really bad exhaust pipes. I use Autosol with steel wool when doing a really bad exhaust pipe. But I wonder if I should do the following, first Autosol with 0000 steel wool, then followed up with P21S Polishing Soap..mmm...:thinking:...:thinking:.
    Any who great review :thumb:
  12. Denzil
    Sounds like a great idea there Carlos! So you're going to tell us how that goes right??? :)
  13. Nica
    Can do :thumb:
  14. P1et
    Awesome test and makes me feel good about having the P21S polishing soap! Smells GREAT too!
  15. buja
    buja Jedi Nuba
    can the polishing soap be used on chrome wheels as well ?
  16. Reflect
    How do you guys apply polishing soap? Do you use the same applicator? How much pressure do you add?
  17. yukonon22
    yukonon22 Wax on..Wax off
    good review been interested in both polishes
  18. 911Fanatic
    To properly use the Polishing Soap, you dampen the sponge, wipe it across the soap and massage the sponge until a foam appears, THEN polish the surface. This should eliminate any chance of marring any surface. Hope this helps.
  19. Carn
    Carn Welcome to Detailing
    Sounds and seems like the polishing soap is the best of the lot, decent price too ;)
    Thanks for the review :mounty:
  20. michakaveli
    Thanks Matrix for the review! I have been looking for a polish to clean up the visible portion of the stainless steel mufflers on my MB and Taurus. Definitely will add this to my DD order.
