Rescuing a severely neglected black paint to show shine (acid rain damages)
Discussion in 'Show and Shine' started by kc's, Jul 13, 2013.
  1. kc's
    kc's Any Rag Vehicle Washer
    Came a badly injured patient with lots of Dermatology issue
    BTW
    do you really need to invest in a very expensive camera to do photo shoot during car detailing or are you a DESKTOP photographer who spent hours in Photoshop-ping
    No offense the usual camera we usually use is the most affordable off the shelf available....when the detail is right & done correctly everything will be picked up
    needless to use any expensive stuff to cover it or bring it up
    PICTURE saves all the say
    with full of Dermatology issue
    deeper leporsy like infested issue
    how can one go and not cared for such an issue
    when the pre-clear coat days (1K paint) usually requires a lot of care and attention, as it is easily stained or oxidizes.........so
    the older generation driver endedd up with alot of waxing job to maintain a good health on their car paint, something they will do on special occasions to provide a little extra shine.but actually something that should be done on a regular basis.
    now with the Clear coat (post Era) lesser effort requires to maintain a good and healthy paint, as it has a protective coat against wear and tear, still many had the misconception (treating their ride like BULLET PROOF). No No mentality!!!!!!
    Dermatology issue + Deep Scratches
    tropical issue with Dermatology issue
    The exterior of your car needs regular care as well. While neglecting the paint job may not lead to mechanical performance issues, it will result in a lower resale value, just like if you never changed your oil or got a tune up.
    man best friend signature
    under proper lighting....stains are captured
    more closed up pic
    how to restored...it is like fungus.......
    ta da after restorations
    before
    during deeper correction
    a 50 % /50% comparission
    tada
    lower body
    scratches
    upper body
    man best friends
    before
    tada
    deep issue
    became no issue
    infested
    restored and healed
    chemical used and stained
    after paint correction and alien coated
    more damaged ill looking paint
    now after restorations and ALIEN COATED for optimum protection
    what / where to avoid
    - Road side car wash -
    - Parking under tree (saps)
    - carefree parking (as where and when you like) only inviting abuser to scratch your car
    - partial roofing - tiles wash down stains
    - construction area (misty debris and paint sand blasting to your car) or chemical blow over
    - leaking roof - avoid mineral deposit aka permanent deposit
    what to do
    weekly wash
    montly wax / or get it coated for permanent protection
    moving to engine bay detailing
    tada a 3 years old honda looks like just rolled out from the show room again
    before
    before
    before
    touch up of paint chipped prior coating
    tada
  2. supercharged
    Now, that paint looks HEALTHY! It was looking sick, you prescribed medication and therapy and resolved the issue! Ve
  3. kc's
    Thanks supercharge for yr kind words
  4. kc's
    Remarks
    Alien coat aka optimum opticoat
    (Translate in our local lingo)
    The car is wash by optimum car shampoo with 3 sets of different. Mf for top body, Lower body & lastly the rims
    Optimum powe clean for deeper cleaning
    Clay with onr as lube
    Paint corrected with cutting pad, polishing & finishing optimum pads, ohc ohp
    Onr wash inbetween each step down washing
    Lastly
    Ipa & Ta da opti coat
    We are known as alien, as some accused us of doing results out of the world..... But we only does it passionately
